Fault code meaning?
Jash
Ive got a fault codes on my D2 4.2 98 and iam not 100% shore what it means. Is there anyone who can point in the right direction of things to look at?
16706
P0322
Ign./Distributor Eng.Speed Inp.Circ No Signal
If there is no engine speed how can the engine run fine?:confused:
Any help would be well greatly appreciated+++
16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
Possible Symptoms
Engine shuts off
Engine doesn't start
Speedometer inoperative
Glow Plug Indicator Lamp (K29) flashes
Possible Causes
Engine Speed Sensor (G28) loose
Engine Speed Sensor (G28) faulty
Possible Solutions
Check Engine Speed Sensor (G28)
Special Notes
The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position.
More and more Code:eek:
There are some more codes on my ECU, thay are
Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
Long Term Fuel Trim Add.Fuel,Bank2 System too Lean
Long Term Fuel Trim mult.,Bank2 System too Rich
Iam not shore how it can be running rich and lean at the same time, and I cant clear theses code ether to see if thay come back.
Any idears anyone???:confused:??? Also dose anyone have a pic of the engine management light on as dont think my one is working ether.
Cheers for any help. TSN Rules!!!!
Iam using a program called DiagRA.
Its what we use at work to log data and look at fault codes.
It a powerful bit of kit in the right hands, you can changed engine paramiters as will as all the other useul stuff.
We all so have a old'ish Snapon Scan tool that I mite try.
The only problem is (as well as not clearing the codes) trying to get it out of work to use it, this place is like Fortnocks.
I get a roasting if I get cort by security.
But from the screen shots Ive seen of VAG-Com it look as if thay are very similar.
J
J
Bear in mind fault codes accumulate and are not time specific. If not cleared, you could have been running rich years before the lean problem occured. In these cases you're always best to make a note of the codes and clear them, then start to only worry about any that re-occur...
You can see my problem now with not getting rid of the codes. Lame a!!
If I had more time to play with the laptop at work with DiagRA software I mite be able to find the problem with it.
Think I mite just have to buy VAG-COM and the right cabel so I can do it at home, but then I have all ways got it.
  • 4 weeks later...
Ive got round to doing some more work on the car this last week.
I now have a copy of Vag-Com and cleard the codes I had on the ECU.
Checked them a day later and the running lean on Bank 1 came back and the engine speed signal.
So why I was thinking about what could corse the problem, I stared changing the spark plugs.
As I got down to plug Number 4 I started checking some oily rubber pipes rounld the back of the engine and noticed that the brither pipes from the Cam covers to the T/B had split in 2.:eek:
Blocked the hole in to the T/B and all is well:grin:
Still done know why it has a problem with the engine speed signal, but as long as the engine is running ok I dont think it will be much of a problem. Well, till it brakes for good.
Dose any one know were the sensor is located on a 4.2 ABZ (i think).
Cheers.
