How do I get a ringtone on a 6300?
Muppetboy
If you have the cable for the phone to connect it to the PC use that. Download Nokia PC Suite onto your PC and use that to transfer or you may find it will add itself as a drive on your PC to just drop the files on.
Then copy on an MP3 or WPA file and you should be away, you might need to drop it in the right directory though, its not hard to figure out. +++
Or remove the memory card, put it in your computer sd card slot (in the relevant adapter because it's a micro sd), and then drag & drop your ringtone into it. Then put back in the phone, select your ringtone and click "options", then "set as ringtone".
If you want an actual ringtone then ask away with a request and I'll get it for you. +++
  • 3 months later...
