Zaino products
snelling23
I've used Zaino Z2pro for a good while and find it to be excellent. It lasts a VERY long time and beads really well. As for it and the colour no idea but its a cracking sealant.
I think you can then add Z8 to create a really special finish on top of it then. +++
Hi!
There nice products, been knocking around for a few years but have recently become quite popular in the UK. The bad points are:
-You have to get the prep right, oil bases are no no for this product. Which means are polishing you need to ensure you use a straight up paintwork cleaner, ZAIO, Top Inspection or an Alchol wipe down.
-Durability is not great unless you use the "ZFX" which tend to mean you can get more coats down and it lasts longer. However, you have to mix it, use it in one day and it costs more.
On the upside it provides pretty good looks mostly, the looks last. There is a difference between something being durable and something that holds its looks when its durable.
The product wont work miracles on poor, unprepped finishes. It has almost no filling but it will help to prevent alot of dirt from sticking to the car and make washing easier which is really good for white!
Z8 as mentioned is pretty good, though there a atleast 3 other products on the market that derive the same conclusion with different methods of applicaion etc.
Geoff
  • 2 weeks later...
