j3nn3r Posted March 9, 2009 Report Share Posted March 9, 2009 Have had this show up on the VAG-COM its on a A3 1.8 T AGU engine 01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80) 29-00 - Short to Ground 16486 - Mass or Volume Air Flow Circuit - Low input P0102 - 35-00 - 16518 - O2 Sensor Circuit - No Activity Detected (Bank 1 Sensor 1) 16519 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit Malfunction Sensor Heater Circuit - Malfunction (Bank 1 Sensor 1) P0135 - 35-00 - - Been thinking and it had occured to me that the short to ground and MAF may have a common input somewhere. will also check fuses again. I am in the middle of getting a quote for the O2 sensor replacement, but just seems odd to me that these particular errors would show up together. Idle slighty raised also. Does anyonw know if the J17 Relay or any others may be related to these problems. And where is it. Link to comment Share on other sites More sharing options...
