retepnikrap Posted May 4, 2009 Report Share Posted May 4, 2009 Hi strange thing happened today, turned on my radio and got a LOUD distorted sound just through the Bose bass speaker on the back parcel shelf, no sound through front or rear speakers, the distorted noise was the radio but only just legible through all the distortion. Tried the NAV, TV etc and exactly the same problem, the outputed audio was the right channel, ie NAV when NAV selected TV when TV selected etc but it was very loud, badly distorted and you couldn't turn it down only off. Turned it on and off a few times and problem still remained so gave up, tried it 30 mins later and it was fine, been OK all day so far. Any ideas? Is this problem happened to anyone else? thanks Link to comment Share on other sites More sharing options...
PsYcHe Posted May 6, 2009 Report Share Posted May 6, 2009 Which MMI firmware are you on? Might be something to do with that. I get a similar problem with my home amp (not Bose though) and it gives an immensely loud static type noise with the proper audio in the background on startup now and again. The old reboot seems to do the trick. Link to comment Share on other sites More sharing options...
retepnikrap Posted May 6, 2009 Author Report Share Posted May 6, 2009 How do i check which firmware i have? Is it easy/advisable to update the firmware or is it a job for the stealer? btw, this has only happened once in 4 years. peter Link to comment Share on other sites More sharing options...
PsYcHe Posted May 7, 2009 Report Share Posted May 7, 2009 It's in CAR, Then Setup, then Version if I remember rightly. The string of numbers across the top. Link to comment Share on other sites More sharing options...
j1mvt Posted May 8, 2009 Report Share Posted May 8, 2009 I've got an 04 A8 4.2 with Bose, just get distorted sound through the front left speaker only., for Radio, CD, NAV, TV. I thought an amp may have blown. Based on your experience I'll see what it's like when I drive home tonight, hopefully it's cured itself. If not what's the key sequence to reset the MMI ?. Link to comment Share on other sites More sharing options...
PsYcHe Posted May 8, 2009 Report Share Posted May 8, 2009 top-right meta-key, the centre button and the telephone button at the same time, Link to comment Share on other sites More sharing options...
stig414 Posted May 9, 2009 Report Share Posted May 9, 2009 I've had this on my A6. Unplug the amp in the rear, reconnect and hopefully will be fine from there. The only other solution is to replace the amp, mine was a warranty job! Link to comment Share on other sites More sharing options...
j1mvt Posted May 11, 2009 Report Share Posted May 11, 2009 When I got back in the car, the problem had gone away. All now working fine. Me thinks the clever fault diagnostics systems in the A8 have rebooted themselves in some way. Link to comment Share on other sites More sharing options...
