Audi A4 Cab - Sloshing noise?
disco1
Hi guys,
Very happy with cab motoring, 2.4 very smooth and quite possibly the most relaxing car to drive in the world...ever!
However, sometimes there is a sloshing noise from the passenger side dashboard and last week the was a wet patch underneath the car although no drop in engine/washer fluids.
Could it be water build up (rain) in some unaccesbile part of the chassis/ shell/frame?
Any thoughts?
  • 1 year later...
Yes!! I'm experiencing same water sloshing sound coming from near the passenger door too!? So is that what it is you say - the water drains need clearing under bonnet? thought it was something like that, will give that a go then, nice one!
I've got an A4 cab 2.4 v6 on a 52 plate, not had it long so bit wary about taking it apart if need be which is why thought better get an experts view. But other than that and my boot doors not shutting properly?? I'm lovin it!!?
this is a common problem that everyone must check, there are two drain holes that get blocked, one is under the battery tray and the other is under the brake servo. if its full of gunk/water remove the rubber plugs in the drain holes. if you dont do this then water will build up then over flow into the ecu ending up with an expensive bill !
