HELP audi a4 cab roof and boot
little ted
Hi all i need your help!!!! my partner went to put the roof down on the cab but she came back and sait it will not shut fully.
when i looked the roof storage box was not locked and the roof was nearly closed. so i managed to manually closed the roof but it will now not open, all i get is the roof light on the dash , when i tried to open the boot with the handle it will not open. also when i lock the car with the key fob the indicaters dont flash could this be related ?.
If any body has vag.com in the manchester area wanting to earn some beer tokens it would be helpful before i have to go to audi thanks in advance for any help or advice on this problem
Hi there,
Having had a rather bizarre problem with my roof last week I had to go through manually opening and closing the roof again before it would work at all, (no mean feat getting the roof out of the boot on your own!!). On mine the roof cover decided to stay in the upright position while the rest of the mechanism worked normally which provide much amusement for my neighbour :grin:
I'd say if your getting the roof warning light flashing but nothing is happening either the windscreen latch or the roof cover lock aren't fully clicked into place. Unlatch both of them using the key in the fusebox then re lock them again. This sorted mine.
Despite what it says in the manual mine wouldn't sort itself with the roof cover locked in the upright position, it took me about an hour of opening and closing/locking/unlocking various things before I sorted it :ffs:
Hi Little ted,
Did you get your roof sorted? what happened in the end?
I think i have the same problem. I opened roof, all the way but it would not lock the shelf ( the last bit ) and then as a result it just would`nt complete and the boot locked.
so i manually closed the roof. Tried all the opening/closing tricks and with thr fuse in,out, and the windows up and down.
Today i took the caby to my mate who reset the codes ( there were 3 relating to the problem) and the roof woked 1st time. then we tried again and it would not open the parcel shelf up. So mine is still refusing to work.
anyone have any ideas?
I think it looks hydrolic because its as if it does not have enough power to push all the way through the open closure procedures...... any ideas?
