E51 NGH Posted July 10, 2009 Report Share Posted July 10, 2009 Hi guys, the temperature gauge on my audi a8 2004 is playing up when i start the car up the temperature gauge doesnt seem to work, it stays at zero. but if i then if after a little while i turn off my car then start it up again it goes to 90 and stays there - with no problems any ideas of what i need to do to fix this? Link to comment Share on other sites More sharing options...
PsYcHe Posted July 10, 2009 Report Share Posted July 10, 2009 sounds like it could be the temperature sender... Or maybe the dash cluster. First should be cheap, second isn't! Link to comment Share on other sites More sharing options...
E51 NGH Posted July 10, 2009 Author Report Share Posted July 10, 2009 thanks for the reply. Do you know where I find the temp sender? pictures would help, as I am abit thick! Link to comment Share on other sites More sharing options...
PsYcHe Posted July 11, 2009 Report Share Posted July 11, 2009 Would depend on the engine.... Though not sure where they are on the D3 engines https://erwin.audi.com/erwin/performSearchArticle.do Would help. It's only €4 for an hour of searching and is the proper Audi documentation. Link to comment Share on other sites More sharing options...
E51 NGH Posted July 12, 2009 Author Report Share Posted July 12, 2009 I think I best get a diagnostic test done as the Emissions COntrol System warning light has just come on Link to comment Share on other sites More sharing options...
E51 NGH Posted July 13, 2009 Author Report Share Posted July 13, 2009 booked in for a diagnostic test for wednesday at Autotechnik anyone had any dealings with them? Link to comment Share on other sites More sharing options...
E51 NGH Posted July 15, 2009 Author Report Share Posted July 15, 2009 had the diagnostic test need to replace the temperature sensor has anyone got any idea how I go about trying to do this myself? PsYcHe link above didnt give me what I needed Link to comment Share on other sites More sharing options...
Figure11 Posted July 15, 2009 Report Share Posted July 15, 2009 (edited) Which engine code do you have? There are several temperature senders and sensors. Temperature sensors are for outside and climate control and senders for the coolant system. Do you have any codes? Having said that they all use the same senders 06A 919 501 A and 059 919 501 A Edited July 15, 2009 by Figure11 Link to comment Share on other sites More sharing options...
E51 NGH Posted July 16, 2009 Author Report Share Posted July 16, 2009 thanks for the response the fault code was 16502 P0118 Sender for coolant temperature - G62 signal too high engine code is BFM Link to comment Share on other sites More sharing options...
E51 NGH Posted July 18, 2009 Author Report Share Posted July 18, 2009 all sorted changed the coolant temperature sensor, ECS light gone off, temperature working as normal. Garage quoted me £120 plus VAT, but thought I'd have a go myself. Sensor cost me under £10 and took half hour! Link to comment Share on other sites More sharing options...
