temperature gauge
E51 NGH
Hi guys,
the temperature gauge on my audi a8 2004 is playing up
when i start the car up the temperature gauge doesnt seem to work, it stays at zero.
but if i then if after a little while i turn off my car then start it up again it goes to 90 and stays there - with no problems
any ideas of what i need to do to fix this?
Which engine code do you have?
There are several temperature senders and sensors.
Temperature sensors are for outside and climate control and senders for the coolant system. Do you have any codes?
Having said that they all use the same senders 06A 919 501 A and 059 919 501 A
Edited by Figure11
