Harmar Superstar Posted November 24, 2009 Report Share Posted November 24, 2009 (edited) Morning all, Long time reader first time poster (how lame) I've got an A4 Sport 130 TDi which has developed a problem starting (past few weeks) takes 2 / 3 attempts to start and when it does turn over, it puts on a floor show by billowing white smoke out the back. However, when it's warm, no problems. Power seems a little lacking although iit could be just my perception as I'm driving cautiously. I've bitten the bullet and it's sat in Audi as we speak for a cold start diagnostic. (£117) After a lot of googling it would appear it could be injectors or something. Anyone else had this? Cars been in since last night, It's now 10:40am... I'm not convinced this is going to be good news! Edited November 24, 2009 by Harmar Superstar Link to comment Share on other sites More sharing options...
Bluedan Posted November 24, 2009 Report Share Posted November 24, 2009 Glow plugs?? Link to comment Share on other sites More sharing options...
Harmar Superstar Posted November 24, 2009 Author Report Share Posted November 24, 2009 Just had a phone call from Audi. They found a fault in the temperature sensor and are on record as stating that this is the fault causing the problem. I'm not convinced but we'll see tomorrow morning. If it's not I take it I'm in a good position to have it repaired free? Why would the temp sensor cause a problem starting? Link to comment Share on other sites More sharing options...
shark_90 Posted November 24, 2009 Report Share Posted November 24, 2009 It could well be the temperature sensor. There's two circuits, one that tells the ECU what the temperature is and one that tells the dashboard, so even if your dashboard it reading correctly, the ECU could be seeing something completely different. If the ECU is seeing an incorrect reading it perhas won't know that the engine is cold and therefore start up in the correct mode. Although to be honest is does usually happen the other way around and display itself as a hot start problem. Link to comment Share on other sites More sharing options...
Harmar Superstar Posted November 24, 2009 Author Report Share Posted November 24, 2009 It could well be the temperature sensor. There's two circuits, one that tells the ECU what the temperature is and one that tells the dashboard, so even if your dashboard it reading correctly, the ECU could be seeing something completely different.If the ECU is seeing an incorrect reading it perhas won't know that the engine is cold and therefore start up in the correct mode. Although to be honest is does usually happen the other way around and display itself as a hot start problem. Well they're charging me £200 to do it (including the £117 'diagnosis' charge) so with new wiper blades, MOT (pass first time) and a full service I now owe them £496... ooch Link to comment Share on other sites More sharing options...
shark_90 Posted November 24, 2009 Report Share Posted November 24, 2009 I need to put my prices up! Link to comment Share on other sites More sharing options...
Harmar Superstar Posted November 24, 2009 Author Report Share Posted November 24, 2009 I need to put my prices up! Or find more stupid customers like me! If you want a SAN network merging into your Fibre, or an ESX server setting up, I'm your man. Cars? Basic knowledge!! Link to comment Share on other sites More sharing options...
shark_90 Posted November 24, 2009 Report Share Posted November 24, 2009 Or find more stupid customers like me!If you want a SAN network merging into your Fibre, or an ESX server setting up, I'm your man. Cars? Basic knowledge!! Funny you should mention that, I do SANs too. I'm not that hot on ESX, but can find my way around Link to comment Share on other sites More sharing options...
Harmar Superstar Posted November 24, 2009 Author Report Share Posted November 24, 2009 haha You're obviously more into your cars than I am then! I get in, turn the key and harrass people. Get out of car and harrass them some more. Link to comment Share on other sites More sharing options...
