jimbutler Posted January 21, 2010 Report Share Posted January 21, 2010 Chaps My bizarre electrical gremlins took out my immobiliser, I suspect it has been attacked by the same dampness as the keyless entry ECU. I want to find out before anything else stops working, so can anyone tell me where these ECU's are located. Car is an 03 D3 4.2 Quattro. Also is there an easy way to get the drivers door trim off without breaking anything - need to take a peek at the window wiring to see if there's an obvious cause for my headlamp switch off when window closing issue. Cheers Jim Link to comment Share on other sites More sharing options...
PsYcHe Posted January 22, 2010 Report Share Posted January 22, 2010 If you undo the Torx bolts holding the passenger seat down and slide/lie it back to the rear seat, you can lift the carpet up and they're under the passenger's feet. Link to comment Share on other sites More sharing options...
jimbutler Posted January 22, 2010 Author Report Share Posted January 22, 2010 Looks dry in there, but I will take a closer look now I know where the ECU's are. Thanks Jim Link to comment Share on other sites More sharing options...
PsYcHe Posted January 23, 2010 Report Share Posted January 23, 2010 There may be some on the driver's side too possibly. Link to comment Share on other sites More sharing options...
