San- Posted April 26, 2010 Report Share Posted April 26, 2010 Last week I had my turbo changed for a heafty price. I got the car back and the turbo kept cutting out at around 65/70mph. (minimal power and drive when it cuts out) Switching the car off and on again seemed to reset the turbo untill you again reached that speed and it drops out again. At this point the Engine Management Light came on. Diagnostics check showed 3 errors. 1, Mass air flow meter (which I changed but it had no effect as turbo was still cutting out) 2, Pressure Boost Solenoid (or a Thrust Sensor as Audi like to call it) which I canged and seemed to do the trick. 3, Glow plugs which neither me or the mechanic thought should have any effect on the turbo or the light. After changing the pressure boost sensor the turbo still cut out a couple of times but some reving to get any oil resedue left in turbo pipes sorted that out. Now the car drives fine, but the engine management light can come on again???????? Can anyone help me with why its come back on (when the last diagnostic check showed no errors) and how can I switch it off as the car is driving fine??? Any help would be much appreciated. Thanks. Link to comment Share on other sites More sharing options...
shark_90 Posted April 26, 2010 Report Share Posted April 26, 2010 If the engine management light is on, then there must be a fault stored. The only way to turn it off is to clear the fault(s). Link to comment Share on other sites More sharing options...
SAiLO Posted April 29, 2010 Report Share Posted April 29, 2010 I'd scan the car with VCDS again. If the engine management light is on then a scan should come back with some errors. Link to comment Share on other sites More sharing options...
San- Posted May 14, 2010 Author Report Share Posted May 14, 2010 Just thought I would update. I ended up taking it to a different mechanic and he scanned it again, it showed the mass air flow meter again. It turns out the first dodgy mechanic sold me a second hand one that was already faulty. Have since put in a new Mass Airflow meter and switched the light off. It now shows no errors and the light isnt coming on anymore. Link to comment Share on other sites More sharing options...
cruiser647 Posted May 14, 2010 Report Share Posted May 14, 2010 Does that mean your turbo was changed for no reason? Or was the turbo properly fubared? Link to comment Share on other sites More sharing options...
San- Posted May 21, 2010 Author Report Share Posted May 21, 2010 Yeah I think I got shafted good and proper mate, the turbo did need taking off because the fan had siezed and it was screaming like a mother! But from what av been told, once you have taken the turbo off, you can take out the fan and clean/change it and put your old turbo back on at a fraction of the price! Link to comment Share on other sites More sharing options...
