A4 Cab roof storage lever broken
ridz
Hi all im a newbie to this site so hi to all.
I have a 2007 A4 2.0 TDI S-Line Cabriolet
The wife has just forced the roof storage box lever (that's in the boot) over with the roof down ! :confused: The lever nows just swings free.
Has anybody else had this probem and is it a DIY fix.
I have had a look and have taken some bits of trim off and the wire is still connected to the level, but there the trail ends as I cannot work out where the wire goes to behind the trim panels.I assume there are some cams or wheels where the wire must run in order for the storage box to operate and maybe the wire has just come off.
Any help would be most welcome +++
Car just out of it's warrentee last month- bummer!!
Hi & welcome!
I did this with my lever last year! You can buy just the handle from the dealer for less than £20. It's simple to fit & you don't need to remove all the trim. When you see the new handle you should be able to see where the toggle on the end of the cable fits into it. Hope this helps.
Marko
