satnav installation.
fozi.g
Hi guys.
i've got a pre facelift S8 (1998) with nav but no screen. i wanted to find out whether i could install a facelift satnav/tv with the screen on mine. it seems pretty straight forward. the whole centre console is the same dimension on both cars, just one has a screen where mine doesn't. i dont think it would be plug and play but i cant see it being too much of a drama.
any help would be appreciated.
thanks
foz+++
It's not as easy as that unfortunately.
The FL unit has CAN-bus, and expects a different display, etc. Not impossible, but not easy.
You'd be better looking at a third party solution, which although you probably wouldn't get the centre display, would be easier to fit.
The Sat Nav retro fit is easy enough, no real drama there. Getting the facelift climate module to work with PF wiring loom is the pain as the A/C on facelift expects the canbus to deliver signals for engine speed etc so it can turn the A/C compressor on.
TV retrofit is probably not worth it. Cars with factory TV have single pane rear screens to help the signals get through, so unless you have a 2.8 with single pane, it'll probably not work too well.
Although I hate aftermarket, I have to agree its probably the most sensible option for a PF D2....
