jake_0121 Posted August 22, 2010 Report Share Posted August 22, 2010 hi iv jus brought a 2004 aud a3 2.0 fsi full s3 replica, the engine is missfiring and dosnt sound health at all. so im looking for some advice on a tfsi conversion, what parts will i need? is it a straight out straight in job? any help will be appritiated, jake Link to comment Share on other sites More sharing options...
shark_90 Posted August 22, 2010 Report Share Posted August 22, 2010 Not sure about the straight out straight in thing although it's probably not that bad as I imagine the subframe is the same. You'll need a TFSI ECU to go with the engine, and you could either use your existing clocks and key with some ECU work which we could do, or you'll need the clocks and key that goes with the TFSI ECU. Link to comment Share on other sites More sharing options...
jake_0121 Posted August 22, 2010 Author Report Share Posted August 22, 2010 damn, i can get a 2008 s3 engine and wiring but he has no ecu!! will the engine mount up on the same mounts? also what would be the best gearbox option? thanx Link to comment Share on other sites More sharing options...
shark_90 Posted August 22, 2010 Report Share Posted August 22, 2010 I don't know if it will mount on the same mounts but I have a feeling it will. I have a suitable ECU. Link to comment Share on other sites More sharing options...
jake_0121 Posted August 23, 2010 Author Report Share Posted August 23, 2010 so if i can get the engine to mount up and wired in ok ur ecu will fire it up? is it an aftermarket ecu? how much would you be looking for it? cheers Link to comment Share on other sites More sharing options...
