Deckard Posted August 25, 2010 Report Share Posted August 25, 2010 (edited) Hi guys....I know I shouldn't have fiddled but I've managed what looks like setting the car up for LHD. When I open the driver's door the passenger door graphic lights up. Mileage is now in kilometers and the fuel consumption is now in litres/100KM. I feel such a tit for getting this wrong :o:o What do I need to do fix it? I'm using an ebay cable with VAG-K+CAN 1.4 program from Hong Kong The only modules I was aware of fiddling with were 07 (Kombi) and MMI Cockpit although I've a feeling it's something in 07 I've buggered around with Any help will be gratefully accepted cheers D Edited August 25, 2010 by Deckard Link to comment Share on other sites More sharing options...
Deckard Posted August 25, 2010 Author Report Share Posted August 25, 2010 The program I used is VWtester and I'm *SURE* I pressed the Coding button whilst in ECU 07 and I changed the code to '1' from whatever it's meant to be!?!?!? Link to comment Share on other sites More sharing options...
PsYcHe Posted August 25, 2010 Report Share Posted August 25, 2010 Yep.. I did something similar Can't remember the actual coding, as VCDS gives you the hints. Where are you located? Maybe someone local will be along soon. Link to comment Share on other sites More sharing options...
Deckard Posted August 25, 2010 Author Report Share Posted August 25, 2010 Yep.. I did something similar Can't remember the actual coding, as VCDS gives you the hints. Where are you located? Maybe someone local will be along soon. I'm in Scotland. Near Dundee. I'll have a look at VCDS but u can't get the lite version to connect?!? Link to comment Share on other sites More sharing options...
Deckard Posted August 26, 2010 Author Report Share Posted August 26, 2010 Anyone? I'm panicking a bit here..... Link to comment Share on other sites More sharing options...
Deckard Posted August 26, 2010 Author Report Share Posted August 26, 2010 I've just realised there's a dedicated VAGCOM forum so I've repeated the request over there http://www.tyresmoke.net/forum/vag-com/128164-audi-a8-help-needed-ive-changed-my-country-setup.html#post1504125 Link to comment Share on other sites More sharing options...
PsYcHe Posted August 27, 2010 Report Share Posted August 27, 2010 Deckard - I was passing through Dundee on the way to Aberdeen yesterday as well. Did we previously have a conversation about helping you and you were stuck at a desk? Or was that someone else? You free on Monday? Link to comment Share on other sites More sharing options...
Deckard Posted August 29, 2010 Author Report Share Posted August 29, 2010 Thanks for the offer PsYcHe but I've managed to figure it out....phew (And yes, I'm the guy tied to the desk ) Link to comment Share on other sites More sharing options...
sloss Posted August 31, 2010 Report Share Posted August 31, 2010 So how did you get it back to 'normal' - just in case....... Stew, Link to comment Share on other sites More sharing options...
ollya Posted October 22, 2010 Report Share Posted October 22, 2010 Sorry, I know this is an old post, but any chance Deckard (or anyone else) could post the solution please? I've gone and done the exact same thing and set my coding to 1, and everything is in LHD mode. I guess I just need to know the original coding for a 2004 UK A8 or another method of getting it back. Cheers Link to comment Share on other sites More sharing options...
Deckard Posted October 23, 2010 Author Report Share Posted October 23, 2010 Hi there - I used one of the cheap Chinese ebay cables with doen't work with the official Vagcom software. Using the software that came with the cable I changed to code to 16443 - you might need to add 00 to the front ie 0016443...can't remember:o This sorted out my 2004 UK A8 hope this helps mate Deckard Link to comment Share on other sites More sharing options...
Deckard Posted July 2, 2011 Author Report Share Posted July 2, 2011 Hi - just realised someone has done the same thing I did!! Using the VWTester program I enter the 07 Kombi module and entered 0000443 and bingo!! I used the following coding info: Coding ????xxx: Options +0016 = Tire Pressure Monitoring System (MY 2005+) +0032 = Advanced Frontlightning System (MY 2006+) [*] xxxx?xx: Country 0 = Germany 1 = Rest of World (Left-Hand-Drive) 2 = USA 3 = Canada 4 = Great Britain 5 = Japan (Left-Hand-Drive) 6 = Arabian States 7 = Australia 8 = Rest of World (Right-Hand-Drive) 9 = Japan (Right-Hand-Drive) [*] xxxxx?x: Seatbelt Warning (3-6 = MY 2005+ only) 0 = No Seatbelt Warning 1 = Seatbelt Warning (EU-NCAP) 2 = Seatbelt Warning (NAR Old) 3 = Seatbelt Warning (NAR New) 4 = Seatbelt Warning (EU-NCAP incl. Passenger) 5 = Seatbelt warning (NAR Old incl. Passenger) 6 = Seatbelt Warning (NAR New incl. Passenger) [*] xxxxxx?: Illumination I (without Parking Light LED) 0 = Needles OFF and Scales OFF (Term. 15 ON / Term. 58 OFF) 1 = Needles ON and Scales OFF (Term. 15 ON / Term. 58 OFF) 2 = Needles OFF and Scales ON (Term. 15 ON / Term. 58 OFF) 3 = Needles ON and Scales ON (Term. 15 ON / Term. 58 OFF) 4 = Needle ON and Scales ON (Term. 15 OFF / Term. 58 OFF) [*] xxxxxx?: Illumination II (with Parking Light LED | MY 2005 only) 5 = Needles OFF and Scales OFF (Term. 15 ON / Term. 58 OFF) 6 = Needles ON and Scales OFF (Term. 15 ON / Term. 58 OFF) 7 = Needles OFF and Scales ON (Term. 15 ON / Term. 58 OFF) 8 = Needles ON and Scales ON (Term. 15 ON / Term. 58 OFF) 9 = Needles ON and Scales ON (Term. 15 OFF / Term. 58 OFF) Link to comment Share on other sites More sharing options...
