ken Posted November 28, 2010 Report Share Posted November 28, 2010 Hi, Any one know the routine to repair the electric window mechanism on the drivers door of my passat. Came out this morning started the car to warm it up and after 15 minutes I tried to open the window and something inside the door snapped and now the window will not work.The electric motor works and i can hear something loose turning inside the door about 6 inches down the door,sounds like something has snapped due to the frozen up window.Thanks. Ken Link to comment Share on other sites More sharing options...
TIDYDUBS Posted November 28, 2010 Report Share Posted November 28, 2010 Could be routine but not that common, although it does sound like your window reg has pinged. You will probably have to replace the window regulator assembly carrier complete. Door trim off and a series of torx 30 screws you dont need to change the motor/control unit that comes off(a further 3 torx 30 screws.) Outer door handle and the screws and M6 or M8 spline for screws on door latch too it really is a fiddle...............dont attempt this if you really have A. limited patience and start cursing it B no idea or C bugger it its too dam cold out there to attempt this ill pay some one to do it. You will need and external torx drive not sure on the size to clamp the window in the reg. Regards Tidy Link to comment Share on other sites More sharing options...
ken Posted November 28, 2010 Author Report Share Posted November 28, 2010 Cheers for the info,sounds fiddly and i have never changed one before.Any idea what it will cost at main dealers,got a quote for window ass. part of £115+vat and labour to go on that.Any one know of a good independent VW garage in or around the manchester area? Thanks Link to comment Share on other sites More sharing options...
TIDYDUBS Posted November 28, 2010 Report Share Posted November 28, 2010 A main stealer will possibly charge just over an hour plus vat find a good specialist Indy.......... Link to comment Share on other sites More sharing options...
