Removing boot lid trim - 2007 Cabrio
aero-mandolin
From 'Elsawin', with some additions by me, learned when I was looking for the broken aerial lead....
Removing:
– Remove the hazard warning triangle if provided.
– Unscrew the bolts (2x). (Behind the triangle)
– Detach the hazard warning triangle holder.
– Detach the lock cover. (Just prise it off with a screwdriver)
– Slacken off the bolt in the pull-down handle
Unfasten boot lid trim at clips (12x). Again, gently prise the trim panel off with a screwdriver, after the first couple of clips you will be able to see where you are going.
– Detach boot lid trim.
Refitting is the same in reverse.
