Daddytron Posted February 4, 2011 Report Share Posted February 4, 2011 My windshield washer pump is not working, although the headlight sprayer is. From what I can see there is only the one pump in the tank. I have checked all the fuses and they are all good. Any suggestions? Link to comment Share on other sites More sharing options...
sloss Posted February 11, 2011 Report Share Posted February 11, 2011 THere are 2 pumps - one for the Windscreen and one for the Headlamps. If the water level falls too far the Headlamp ones stop working so there is water left for the Screen. You need to take a front wheel and the inner cover off to get at the reservoir/pumps to see if it's getting electric or not. I assume you are not hearing it pump with no water coming out which would just be a blockage..... Link to comment Share on other sites More sharing options...
s8mac Posted February 21, 2011 Report Share Posted February 21, 2011 my washers ar doing the same i headlight washers work fine b*ut the windscreen ones dribble out eventually but the pump is making a whirting noise as if it is not in water. need to get it apart and have a look. perhaps there is a split pipe ? Link to comment Share on other sites More sharing options...
RRH685 Posted February 23, 2011 Report Share Posted February 23, 2011 I have a similar problem on my D3. Windscreen washers are working, but it takes a couple of seconds before any water comes through and then its really weak Link to comment Share on other sites More sharing options...
sloss Posted February 24, 2011 Report Share Posted February 24, 2011 That sounds like a simple blockage or at worst pump choked/on it's way out. Link to comment Share on other sites More sharing options...
PsYcHe Posted February 24, 2011 Report Share Posted February 24, 2011 I'd agree with sloss.. pretty sure there's 2 pumps in there. You need to go in from underneath to get to them if I remember rightly, but shouln't be too expensive to replace. Link to comment Share on other sites More sharing options...
RRH685 Posted February 26, 2011 Report Share Posted February 26, 2011 I'll have a look, thank you. Link to comment Share on other sites More sharing options...
Pentathlete Posted March 8, 2011 Report Share Posted March 8, 2011 I had exactly the same problem. Just turned out to be a thick black oily residue in the tank(?) that was clogging it all up. Just removed the tanks and cleaned it out. Good as new! Link to comment Share on other sites More sharing options...
RRH685 Posted April 12, 2011 Report Share Posted April 12, 2011 Have you seen this? Might be of help. Sadly it didn't work for me though Link to comment Share on other sites More sharing options...
IceBlue8 Posted April 12, 2011 Report Share Posted April 12, 2011 Had a similar problem on mine - turned out to be a disconnected pipe at the back of the engine bay close to the wiper motor. Worth checking before you take out the wheel arch liner Link to comment Share on other sites More sharing options...
greyish Posted July 30, 2011 Report Share Posted July 30, 2011 My windshield washer pump is not working, although the headlight sprayer is. From what I can see there is only the one pump in the tank. I have checked all the fuses and they are all good. Any suggestions? there should be a series of small hoses from the tank to the sprayers on the windshield. in some cases, there are separate pumps, but most likely not. take sections off the hose path from the tank to the windshield until you find one that isn't putting out flow on demand - you have a blockage. If there ARE multiple pumps, then check the fuses and/or relays in the system. Fuses are easy to check with a multimeter, and relays can be swapped with similar ones to check and see if they are failed. Link to comment Share on other sites More sharing options...
greyish Posted July 31, 2011 Report Share Posted July 31, 2011 (edited) My windshield washer pump is not working, although the headlight sprayer is. From what I can see there is only the one pump in the tank. I have checked all the fuses and they are all good. Any suggestions? there should be a series of small hoses from the tank to the sprayers on the windshield. in some cases, there are separate pumps, but most likely not. take sections off the hose path from the tank to the windshield until you find one that isn't putting out flow on demand - you have a blockage. If there ARE multiple pumps, then check the fuses and/or relays in the system. Fuses are easy to check with a multimeter, and relays can be swapped with similar ones to check and see if they are failed. Edited July 31, 2011 by greyish Link to comment Share on other sites More sharing options...
