micalee Posted February 25, 2011 Report Share Posted February 25, 2011 Is it me, or is it only the passenger seat which easily tilts then slides back to the original position? only, the drivers side does not slide back - I have to use the lever under the seat Link to comment Share on other sites More sharing options...
burble Posted February 25, 2011 Report Share Posted February 25, 2011 Are you sliding the seat back whist the seat back is still leaning towards the front of the car? Link to comment Share on other sites More sharing options...
micalee Posted February 25, 2011 Author Report Share Posted February 25, 2011 Hi Burble - I lean the seat forward by lifting the handle at the top of the seat, but it will not slide forward from that point onwards, so I have to use the lever under the seat - likewise, it will not slide back. The passenger seat does slide forward as soon as the seat leans forward - couldnt do it in my last R either! Link to comment Share on other sites More sharing options...
burble Posted February 25, 2011 Report Share Posted February 25, 2011 Hmm, my drivers seat works fine. Make sure you give the seat back a good shove forward with the handle still up and see if it'll slide then. I know with mine if the seat back isn't forward enough then it won't slide. Link to comment Share on other sites More sharing options...
micalee Posted February 25, 2011 Author Report Share Posted February 25, 2011 Ill give it another try - raining now, so will report in when done. Cheers Link to comment Share on other sites More sharing options...
Cuprabob Posted February 25, 2011 Report Share Posted February 25, 2011 On my Recaros neither the driver's or the passenger seat tilts and slides in one operation. To let anyone in and out it's a major exercise as you need to operate both levers seperately. Luckily I don't use the back seats that often :-) Link to comment Share on other sites More sharing options...
micalee Posted February 25, 2011 Author Report Share Posted February 25, 2011 On my Recaros neither the driver's or the passenger seat tilts and slides in one operation. To let anyone in and out it's a major exercise as you need to operate both levers seperately. Luckily I don't use the back seats that often :-) My first R32 had the more expensive Recaro's, and didnt work on either seat also! Agree, Was a task! Link to comment Share on other sites More sharing options...
Tipex Posted February 25, 2011 Report Share Posted February 25, 2011 Sounds like VW couldn't be arsed to do a proper RHD conversion! Link to comment Share on other sites More sharing options...
micalee Posted February 26, 2011 Author Report Share Posted February 26, 2011 Tried again tonight, just wont slide! Link to comment Share on other sites More sharing options...
TIDYDUBS Posted February 27, 2011 Report Share Posted February 27, 2011 That will be you easy entry cable needs replacing under the seat......common problem+++ there are modified ones. Id be doing the other side too, should only take approximately 10 minutes a side Link to comment Share on other sites More sharing options...
micalee Posted February 27, 2011 Author Report Share Posted February 27, 2011 Are you able to post a pic of what I should be looking for? Link to comment Share on other sites More sharing options...
micalee Posted February 27, 2011 Author Report Share Posted February 27, 2011 Taken a look under the seat and can see the cable which pulls the mechanism which allows the seat to slide. The passenger seat works fine and it is loose on the drivers side, but cannot for the life see where it secures or how I can fix it Link to comment Share on other sites More sharing options...
TIDYDUBS Posted March 1, 2011 Report Share Posted March 1, 2011 Will try and dig some info out for ya Lee on how and what my friend ok? Link to comment Share on other sites More sharing options...
micalee Posted March 3, 2011 Author Report Share Posted March 3, 2011 Many thanks Tidydubs Link to comment Share on other sites More sharing options...
