Ally Pally Jungle Raver Posted June 27, 2011 Report Share Posted June 27, 2011 Hello everyone I have a problem that really does my head in.....HELP When I for example floor the car (within the speed limit) sometimes the power just dies.....untill I turn the car off and then on again It feels like the turbo just stops working, like I said untill I turn it off and on Its just as it resets somethng And I get the feeling its a sensor HELP will be verry appreciated.....THANK YOU Link to comment Share on other sites More sharing options...
cruiser647 Posted June 28, 2011 Report Share Posted June 28, 2011 You might need a new MAF (or to clean the MAF). It measures the air temp and sits just behind the air filter in the pipe to the inlet manifold. Get some carb cleaner from Halfords and clean it EXTREMELY gently with a cotton bud after spraying it with the cleaner. You might also want to check all the air pipes too and from the turbo and also clean the EGR with the same fluid. It can clog up. Do a search on here for MAF & TDi EGR, you should find some pictures for it to help you. Good luck! Link to comment Share on other sites More sharing options...
vwsteve Posted June 28, 2011 Report Share Posted June 28, 2011 hi you have a turbo problem the vanes are sticking you could try aproduct called inotec but the best way is to remove turbo and strip it apart and clean the vanes hope this helps Link to comment Share on other sites More sharing options...
NewNiceMrMe Posted June 28, 2011 Report Share Posted June 28, 2011 I don't care what the problem is, but I love the user name. Link to comment Share on other sites More sharing options...
