Thinking of Z4M
robbie_n
Hey all,
I am thinking of purchasing a z4m roadster at around the £15-20k Mark.
I used to own a coupe version from new for 2 years and had no issues other than a seized brake caliper. Just wondering if long term reliability is good and what to look for on 5-6 year old models. I remember the mesh between 1st and 2nd being awkward at low engine speeds, anyone had issues with this getting worse.
Also are there any major service bills due such as cam belt or water pump change that would be due around 50k/6 years?
Any relevant comments or experiences greatly appreciated.
Hey Robbie,
The Z4M is built on tried and trusted tech (e46 M3/CSL)... so there's really nothing untoward to go wrong really, as long as it's had the run-in service at c1200 miles and a full service history it'll be fine. Just double double make sure the brake disks are true and not warped, they can be very heavy on the disks.
Like you mentioned, 1st to 2nd gear can crunch when cold, but there's no fix, you either get a box with it or you don't. £15k will get a leggy c3yr old model, £20k a fully loaded low-mile minter.
This to tide you over till the RS3 turns up ?
One quick point I'd make is to make sure you test drive one on the roads you'll be using it on. Try to get one for a couple of hours.
The reason I say it is that a good few owners find the ride very hard indeed once they start doing normal commutes in the car. Personally I didn't have any issues in the few I drove, but it should be noted that was for an hour here, an hour there, etc. I much prefer the Z4M Coupe as a 'looker', but again many owners can't live with the ride.
Oh and get the biggest engined model possible.
Hey Robbie,
Thinking of it as a play toy so as to still have a "drivers car" (whatever that may be) to use every once in a while - the RS3 will be my daily commuter and will rack up the miles pretty quickly. I always loved my old coupe and the 3.0 Z4 I had before that so I guess its partly an investment too as I will probably keep this for the long term.
My Z4m coupe was on 18's and even that tram lined badly on certain roads - hate to think what it would be like on 19's. Does the handling improve that much as I found the cornering capabilities pretty high even on the 18's.
As regards the comment on ride, I never found that to be much of an issue and found the suspension/tyre setup to be more forgiving than that on my current 335i which runs on 19" tyres made of stone. My main worry was the gearbox but I guess like you say you either get a good one or a bad one - I would imagine the majority are good.
  • 2 months later...
