2002 Passat TDI 130 - N75 Valve / ECU Problem - AVF Engine code
kder
Hi,
I have a problem with my passat with the N75 not operating. Checks done so far:
1. Checked for vacuum at the N75 vac side - 25inhg, no vacuum on out side.
2. Replaced N75 with new valve but still not operating.
3. Checked wiring to N75 valve. Measured resistance and voltage drop from N75 valve plug to ECU plug - all fine.
4. Jumped N75 valve plug power side and set up other terminal to vechicle earth - N75 valve operates fine with manual earth. Good vacuum on out side and turbo actuator operates.
The fault seems to be in the ECU. Is there any other checks I need to perform?
Any other ideas?
Thanks.
Ran VCDS-Lite and the following code was displayed
1 Fault Found:
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
P1156 - 35-10 - - - Intermittent
Cleared the code a few times but it reappeared immediately. Do I need to replace this sensor or should I check the wiring also?
