Engine Mount Location ?
Gaity
Morning all,
I have a 2003 Audi A8 4.2 (D3 model) and I have what appears to be a fairly common fault code as follows:-
  • 17981: Left engine mount solenoid valve (N144): open circuit
I appreciate that it doesn't really impact anything major but someone advised that it could just be a wiring issue.
In this respect can someone tell me where these wires are in the engine bay? (apparently 2 wires going into a grey connector)
Cheers all ;)
I get error codes for left and right mount.
I saw them when lying under the car after taking the plastic tray off, you can see the connectors, but they would be hard to unplug due to tight space and the clips.
I read on other websites that later models dispensed with this system anyway, and that Audi black off the plugs with terminators if you take it to them.
