beemerboy9 Posted December 26, 2011 Report Share Posted December 26, 2011 Hello folks, I blew an o/s dipped beam bulb driving home on Xmas day. Replaced it today by removing o/s air filter and then moving headlight forward a tad to be able to apply enough pressure to rotate the bulb holder. Bulb failure warning now gone but the bonnet open icon has replaced it. Applying downwards pressure to the far RHS of the bonnet extinguishes the warning icon, but I cannot get it to stay off. Is there a neat trick to fixing this problem? Thanks in advance, John Link to comment Share on other sites More sharing options...
PsYcHe Posted December 27, 2011 Report Share Posted December 27, 2011 Is the catch properly tightened to the cross member? Or maybe a spray with wd40 and a wiggle. Could be either loose, or some crud in the sensor. Link to comment Share on other sites More sharing options...
beemerboy9 Posted December 27, 2011 Author Report Share Posted December 27, 2011 Psyche, thanks for the reply. Where is the sensor and could I have dislodged it when moving the headlight assembly forward? TIA, John Link to comment Share on other sites More sharing options...
PsYcHe Posted December 28, 2011 Report Share Posted December 28, 2011 It's part of the latch mechanism as far as I know. Link to comment Share on other sites More sharing options...
beemerboy9 Posted December 29, 2011 Author Report Share Posted December 29, 2011 Panic over... A master tech, Matt, at my local Audi Centre (I'll give Whetstone Audi a plug here) pointed to a sticky O/S latch. A clean-up with WD40 and a toothbrush, a touch of Air Duster and a second spray with WD40 sorted it out. I was worried that the car would not shut down completely if the alarm was sensing an open bonnet and the battery might drain. I've done that before after leaving the bonnet open for a fortnight (no, I can't remember why I did that!). Thanks for your assistance, Psyche. John Link to comment Share on other sites More sharing options...
PsYcHe Posted December 30, 2011 Report Share Posted December 30, 2011 No problem... Always nice to see an easy fix Link to comment Share on other sites More sharing options...
