george4law Posted January 29, 2012 Report Share Posted January 29, 2012 Here I am new and trying to solve a clutch problem. Engine off it works fine, after driving for a while, clutch just goes no pressure at all, stop and switch off the engine it comes back again. I appears worse when its cold. changed clutch servo have bleed numerous times. just have no idea, it appears to have a mind of its own. Any ideas ??? g Link to comment Share on other sites More sharing options...
Tipex Posted January 29, 2012 Report Share Posted January 29, 2012 Have you changed the fluid rather than just bleeding it? it's hydroscopic, so absorbs water, and hence doesn't work very well, just like brake fluid, when it gets warm the water in the fluid boils, turns into a gas and compresses, meaning you have no pressure form the pedal. Link to comment Share on other sites More sharing options...
Cuprabob Posted January 29, 2012 Report Share Posted January 29, 2012 My money would be on the slave cylinder. Very common problem on the MK4 Link to comment Share on other sites More sharing options...
