audi a8 3.0 tdi service questions
muppetboy12
Very straight forward if you have done it on other cars.
It is all conventional.
Front brake pads - make sure you get the right ones, use the PR number on the sticker in your wheel-well if not sure.
Brake fluid - You don't need to use VCDS to cycle the ABS pump.
Air filter - put soap or shaving gel on the new one's silicone seal to stop it gripping the housing and getting damaged.
Oil filter - Don't tighten the housing to much.
pollen filter - Remove the 4 plastic chips by turning with a flat blade driver.
Front suspension 'C" links - Easy, but tighten bolts fully with weight on the ground. You make also need to lower the car or jack up the hub to get the bolts in.
Good luck.
  • 2 months later...
