carlsmith Posted April 30, 2012 Report Share Posted April 30, 2012 Hi Anyone got any advice, think my clutch is on its way as it has a very brief slip between 2200 & 2400 rpm at this stage only does it in 3rd 4th &5th. Now i now that you could get an idear if it was on its way on the old handbrake verstion by trying to pull away with the H/Brake on, but due to the H/Brake set up on the newer models this is not possible,, i have tried to heal & toe but does not really work, as someone mentioned possible hydraulic pipe problem,, anyone give any advice,, if so would be most greatfull. Also if the clutch is replaced anyone now if this model has to have the flywheel done also at the same time. Thanks again Carl Link to comment Share on other sites More sharing options...
