matt5791 Posted May 9, 2012 Report Share Posted May 9, 2012 I have an 06 D3 A8 with 19" 12 spoke alloys and a full size spare. Tyres are 255 40 19 - I'm thinking of changing them to 20" wheels with 275 35 20 tyres. Does anyone know if one of these will fit in the spare wheel space under the boot - with the current wheel in position it looks like the larger ones should as there is still plenty of height and some space around, but I'm not sure. Anyone know? Many thanks. Link to comment Share on other sites More sharing options...
Tipex Posted May 9, 2012 Report Share Posted May 9, 2012 If the 20 inch wheels have the same circumference (which they should do with the correct tyres), then they will be exactly the same size, being slightly wider means when laid in the boot it might be too high and lift the floor up. Link to comment Share on other sites More sharing options...
PsYcHe Posted May 9, 2012 Report Share Posted May 9, 2012 That's a 'proper' A8 size, so should be fine. Link to comment Share on other sites More sharing options...
Architex mA8tey Posted May 12, 2012 Report Share Posted May 12, 2012 your new tyres / wheels will be just over 2% larger diameter - see attached comparison. if the new wheels had 255 35 20's on then they would be exactly the same diameter You also need to consider the tyre/wheel width as Tipex suggested, if the new combination is deeper then it may not sit below the cover/floor so just check and see how much spare depth you have first Link to comment Share on other sites More sharing options...
PsYcHe Posted May 13, 2012 Report Share Posted May 13, 2012 If you go with the 255/35/20 then you need to make sure it's the narrower rim, saw one car that had them on the wide rim (9J?) ad they just looked wrong. Link to comment Share on other sites More sharing options...
