driventodespair Posted June 2, 2012 Report Share Posted June 2, 2012 I can not add fingerprints to my user profile - says system error - any thoughts? Where is the OBD connector located?? thank you in advance! Link to comment Share on other sites More sharing options...
ChrissyR Posted June 2, 2012 Report Share Posted June 2, 2012 Diag port is above where your foot would rest on the throttle - bright pink so it can't be missed No idea on the fingerprint sorry Link to comment Share on other sites More sharing options...
jk88 Posted June 10, 2012 Report Share Posted June 10, 2012 I had this problem a while ago and was planning to take to Audi dealer to fix. In fact it was fixed as a result of disconnecting and reconnecting the fibre optic loop (I was taking the glovebox out for fix a rattle). Definitely worth a try as you can easily disconnect the fibre optic loop by accessing the compartment on the left hand side of the boot where several systems are connect by fibre optic. Just unplug one of them (it's the thick twin cable), wait a minute then plug back in. You'll probably hear some ckicking sounds as the systems search for a valid signal while disconnected. Should take no more than 10 mins start to finish. Be interested to know if this works or mine was pure coincidence. Link to comment Share on other sites More sharing options...
