Willy6215 Posted March 18, 2013 Report Share Posted March 18, 2013 Hi my aircon fan is broken. It is the fan which is the smaller of the two at the front of the engine I believe? Does any one know if the connector for this fan is rounded or square ? I believe it's rounded. Also is it easy to replace? Thanks in advance Link to comment Share on other sites More sharing options...
cruiser647 Posted April 2, 2013 Report Share Posted April 2, 2013 Sorry about the lack of reply........ And welcome to TSN. Not sure about the connector. Are you sure it is the connector that is broken and not the fan motor? Link to comment Share on other sites More sharing options...
BigCol Posted June 7, 2014 Report Share Posted June 7, 2014 Yes, easy to remove; Small grub screw on fan frame, undo. Twist fan about 10 degrees and then wiggle out. On replacing route the wiring along the top, the factory route is along the bottom. Route it properly next time you have the lock carrier out. Plugs and top tip; If your car is a B5.5 (2001 to 2005) then buy a B5 (1997-2001) fan for £40 instead of £130+ for a 5.5 one. Cut the plug of and solder your old one on! Link to comment Share on other sites More sharing options...
