jamieg Posted September 26, 2016 Report Share Posted September 26, 2016 Hi all I've a problem with my 2007 2.0TDI Quattro 170, heres whats happening, when towing I get SEL lights up when pulling away hard in 4th gear, up hills also when requesting more power. Also getting these errors without towing now, going up a hill from work I can be 5th gear at 55mph around 2000rpm, when I request more power medium not hard power I get SEL and limp mode. I've checked over the car for VAC leaks and cant see anything. I've also changed the DPF sensor as mine had gone "G450" , the old one wasn't recording the % clogged on the DPF probably for a couple of years as the car hasn't complained about needed a regen, most of my driving is in and around town. An adaptation was run on the new sensor prior to switching on the engine. So original log from towing recently before changing the DPF sensor G450 Sunday,14,August,2016,11:10:27:19797 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 16.8.0.0 (x64) Data version: 20160731 DS254www.Ross-Tech.com VIN: WAUZZZ8E38A014205 License Plate: Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E38A014205 Mileage: 111150km-69065miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-018-BRD.clb Part No SW: 03G 906 018 AQ HW: 03G 906 018 AQ Component: R4 2.0l PPD1.3 G 9971 Revision: --H43--- Serial number: XXXXXXXXXXXXXX Coding: 0000172 Shop #: WSC 00502 210 91535 VCID: 74EC23F717F67AE2B7-8020 1 Fault Found: 000665 - Boost Pressure Regulation P0299 - 006 - Control Range Not Reached - Intermittent - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 5 Fault Frequency: 6 Reset counter: 40 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 2400 /min Torque: 280.0 Nm Speed: 56.0 km/h 79.95 % Voltage: 13.56 V Pressure: 2449.5 mbar Pressure: 1746.6 mbar Readiness: N/A ______________________________________ Also prior to the G450 change Wednesday,24,August,2016,20:53:14:19797 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 16.8.0.3 (x64) Data version: 20160803 DS255www.Ross-Tech.com VIN: WAUZZZ8E38A014205 License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E38A014205 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-018-BRD.clb Part No SW: 03G 906 018 AQ HW: 03G 906 018 AQ Component: R4 2.0l PPD1.3 G 9971 Revision: --H43--- Serial number: XXXXXXXXXXXXXX Coding: 0000172 Shop #: WSC 00502 210 91535 VCID: 74EC23F717F67AE2B4-8020 1 Fault Found: 001137 - Exhaust Pressure Sensor 1 (G450) P0471 - 006 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00010001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 40 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Torque: 136.0 Nm Speed: 5.0 km/h Pressure: 106.5 mbar Text: -105 mbar Text: 252 C Temperature: 19.5°C Readiness: N/A _______________________________________ Since changing the G450 I've had this show up Tuesday,27,December,2016,20:52:56:19797 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 16.8.0.3 Data version: 20160803 DS255Ross-Tech: Home -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-018-BRD.clb Control Module Part Number: 03G 906 018 AQ HW: 03G 906 018 AQ Component and/or Version: R4 2.0l PPD1.3 G 9971 Software Coding: 0000172 Work Shop Code: WSC 00502 210 91535 VCID: 74EC23F714F67AE2B4-50E6 2 Faults Found: 012592 - EGR System P3130 - 006 - Regulation Range Exceeded - Intermittent 000665 - Boost Pressure Regulation P0299 - 006 - Control Range Not Reached Readiness: N/A __________________________________________________ _______________________ When requesting more power up the large hill from work I've now got these popping up. Thursday,22,September,2016,16:40:44:19797 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 16.8.1.3 Data version: 20160902 DS256Ross-Tech: Home -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-018-BRD.clb Control Module Part Number: 03G 906 018 AQ HW: 03G 906 018 AQ Component and/or Version: R4 2.0l PPD1.3 G 9971 Software Coding: 0000172 Work Shop Code: WSC 00502 210 91535 VCID: 74EC23F717F67AE2BA-8020 4 Faults Found: 012592 - EGR System P3130 - 006 - Regulation Range Exceeded - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 14 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 864 /min Torque: 32.0 Nm Speed: 0.0 km/h 21.45 % Load: 21.6 % Lambda: 0.0 % Battery Volts: 1.0 V 000665 - Boost Pressure Regulation P0299 - 006 - Control Range Not Reached Freeze Frame: Fault Status: 11000001 Fault Priority: 5 Fault Frequency: 2 Reset counter: 40 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 2144 /min Torque: 264.0 Nm Speed: 97.0 km/h 68.64 % Voltage: 14.01 V Pressure: 2151.3 mbar Pressure: 1746.6 mbar 005187 - Potentiometer for EGR (G212) P1443 - 007 - Signal too Low - Intermittent Freeze Frame: Fault Status: 00000010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 39 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h 0.00 % Battery Volts: 1.0 V Mass Air / Rev.: 0.0 mg/str Mass Air / Rev.: 0.0 mg/str 012593 - EGR System P3131 - 006 - Regulation Range not Reached - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 39 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 800 /min Torque: 48.0 Nm Speed: 0.0 km/h 0.00 % Load: 0.0 % Lambda: 99.2 % Battery Volts: 1.0 V Readiness: N/A With this issue the car runs fine at idle no issues anywhere apart from this. I've also checked measuring blocks 84, this shows lamda at idle and running, at idle the ECU is dumping 22% of fuel in, when no idle its at 0% - I've read this kinda suggests a vac leak somewhere, I've had a look and listen but can't find anything concrete. I have VCDS and can do live testing so if more probing is required please let me know so I can isolate this little bugg3r. Any help greatly appreciated. Thanks Link to comment Share on other sites More sharing options...
Ian_C Posted September 26, 2016 Report Share Posted September 26, 2016 You might not get a Vagcom reply on here - best to post this on RS246 + Audi SRS where there are a few VCDS users. Link to comment Share on other sites More sharing options...
jamieg Posted October 18, 2016 Author Report Share Posted October 18, 2016 Quote I've now removed the intake manifold and cleaned through, as with the EGR and intake flap, I've replaced all gaskets when putting back - still getting this issue, however not so often anymore, it was appearing between 2400 up to 4500 and this is still the case. I'm also at times getting correct boost, I've logged a few requested against actual and previously the actual was around 1000 below the requested, where as now I'm getting the actual up with the requested, but this error is still popping up now and again. Had it in 6th gear around 1500 requested more power and it SEL'ed before 2000rpm. Link to comment Share on other sites More sharing options...
