Engine stopped suddenly - please help
allankennedy
My 2005 Audi Quattro 2.5 tdi Auto was running perfectly when suddenly, at  fairly high speed going uphill the engine cut out without warning.  No hiccups, no misfiring , just immediately stone dead.
No warnings appeared  on the dash though when I was trying to restart I did see the glow plug light flashing at one point.
The rescue guy squirted something into the air intake and it started for a few seconds then nothing. From this he concluded that the engine is ok mechanically
After being carried home I checked the fuel pump fuse then I loosened a pipe on the fuel filter and found that fuel is flowing when the ignition is switched on but with no amount of cranking will it even try to fire.
I should mention I have run the VAG.com engine  module which did not produce any fault codes . The car has done about 140k miles and had a cambelt change a couple of years ago. Present usage of the car is very light as I am now retired.
Any advice / guidance will be greatly appreciated -- thanks in advance
