Colin M Posted March 19, 2004 Report Share Posted March 19, 2004 Some low life tried to chisel out the lock barrel with a screwdriver on my MK3 Golf (prior to me buying it from my mate). I've had a new barrel for my keys made up and need to remove the handle from the door to get to it. I've tried removing the screw immediately inside the door level with the handle, but no luck. Has anyone done this job before? Link to comment Share on other sites More sharing options...
shao_khan Posted March 19, 2004 Report Share Posted March 19, 2004 Its been a long time, but I recal with your door trim off there was a clip or a screw on the inside you needed to remove to be able to change the lock barrel - I will give it some thought to see if I can remember exactly how it was as had ours in pieces, but years back now. Link to comment Share on other sites More sharing options...
Rafi Posted March 22, 2004 Report Share Posted March 22, 2004 See attached jpeg from the well known repair manual. Hopefully it will help. Link to comment Share on other sites More sharing options...
Colin M Posted March 23, 2004 Author Report Share Posted March 23, 2004 Perfect! I'll sort that out this afternoon. I wasn't undoing the inside handle so the thing was still stuck. Thanks for the image. Link to comment Share on other sites More sharing options...
