martin9aj Posted September 26, 2004 Report Share Posted September 26, 2004 Hey, I have a mk3 golf 2.0 gti 8v 1995 I need to reset the service reminder that flashes on when i turn ignition on. i know it can be done WITHOUT the service resetting tool but i cant remember how i was told it could be done! Any ideas cheers Link to comment Share on other sites More sharing options...
stuartjw Posted September 27, 2004 Report Share Posted September 27, 2004 I just reset the light on mine - It does tell you how to do it in the Haynes manual. It is something like you switch the ignition on then holding down one of the buttons you switch it off. I cant remeber exactly. If you have a haynes manual it does tell you in the service section at the begining. Link to comment Share on other sites More sharing options...
stuartjw Posted September 28, 2004 Report Share Posted September 28, 2004 Turn the ignition on and hold down the reset button on the left of the disply (Wgen reading the mileage - not the trip amount. Now turn the ignition off. The display should read either in 02, in01, oel. USing the reset button again allows you to scroll between them if multiple services are due. When you get to the one you want to reset I think you hold the minute adjust (For the clock) button down for a few seconds till it goes blank. Repeat this to remove all the codes until when you start it up it reads in 00. Link to comment Share on other sites More sharing options...
