cruiser647 Posted October 28, 2004 Report Share Posted October 28, 2004 For the air con compressor, is there a seperate fuse for it? I know there is a RELAY, in position 14 on the passenger side, and a fuse by the drivers right foot, but is there another one somewhere else? If so, does anyone know where it is? Just that my air con does not seem to function - no audible click when turning ir on/off. The relay has been replaced,to no avail. And the fuse by the drivers foot is fine. Many thanks! Link to comment Share on other sites More sharing options...
PaulW Posted October 29, 2004 Report Share Posted October 29, 2004 I'll have to look at it.....but a couple of questions. When going from ECON to ECON off, does the electric fan start and stop? When in ECON, if the engine temp is normal, the electric fan should turn off. If it's still off when in "ECON off" (okay, when the ECON light isn't on), then maybe something wrong with the control circuit. If you look at the compressor, you should be able to see a large green wire I believe coming off of it on the LH side of the engine. It has an electrical connector right there, down near the large "coke can" part of the suspension. If you unplug the connector and check for voltage on the wiring harness side, you'll be able to see if it has power or not. And I don't know if it has a fuse, but will have to check.... pw Link to comment Share on other sites More sharing options...
