Ska Posted March 8, 2005 Report Share Posted March 8, 2005 Can you remove these from underneath in the boot or do you have to take the shelf trim off; hope not on the later Link to comment Share on other sites More sharing options...
williama8 Posted March 9, 2005 Report Share Posted March 9, 2005 Had a quick look at mine, seems they can be removed from inside the boot, had some job removing myself from the boot, getting into the boot is not to be recomended when your 20st Link to comment Share on other sites More sharing options...
Ska Posted March 9, 2005 Author Report Share Posted March 9, 2005 Thamks M8, what worries me is if I crawl into the boot someone will shut the lid on me! Link to comment Share on other sites More sharing options...
crasher Posted March 9, 2005 Report Share Posted March 9, 2005 Do what i do/did. Always leave a leg dangling out. Helps if you're tall (like me)... Link to comment Share on other sites More sharing options...
Ska Posted March 9, 2005 Author Report Share Posted March 9, 2005 That's a good one m8 ... then I'll only have to worry about an amputated leg instead of asphyxiation lol Link to comment Share on other sites More sharing options...
PaulW Posted March 9, 2005 Report Share Posted March 9, 2005 I don't know why you want to remove them, but I had to when I installed my GPS antena under the hat shelf....here's a procedure: http://www.audipages.com/upgrades/navplusgps.html Link to comment Share on other sites More sharing options...
Ska Posted March 10, 2005 Author Report Share Posted March 10, 2005 I'm actually looking for a 5 pin connector to the rear door speakers which from the wiring diagram I was given says is under the shelf hopefuly its close to the rear shelf speaker/ transister set up. I need to connect an external amplifier to it for my audio system, is all. Cheers Link to comment Share on other sites More sharing options...
