Zenyck100 Posted May 24, 2005 Report Share Posted May 24, 2005 as above nees to know which to tap into for the earth on my dension ice link. Link to comment Share on other sites More sharing options...
R32North Posted May 24, 2005 Report Share Posted May 24, 2005 Brown is nearly always live.... ie, Red or Brown - Live Green / Yellow - Earth Blue or Black - Neutral Has been this way for me for years, unless the rules have changed! Link to comment Share on other sites More sharing options...
Zenyck100 Posted May 24, 2005 Author Report Share Posted May 24, 2005 god im thick. i just didnt stop to think for a sec. Link to comment Share on other sites More sharing options...
Skidmark Posted May 24, 2005 Report Share Posted May 24, 2005 [ QUOTE ] Brown is nearly always live.... ie, Red or Brown - Live Green / Yellow - Earth Blue or Black - Neutral Has been this way for me for years, unless the rules have changed! [/ QUOTE ] that is house wiring colours !!! be careful ? Link to comment Share on other sites More sharing options...
Gti_Fly Posted May 24, 2005 Report Share Posted May 24, 2005 Dude, tap into the BROWN wire for earth! Link to comment Share on other sites More sharing options...
Gti_Fly Posted May 24, 2005 Report Share Posted May 24, 2005 On my Satnav unit, the Brown wire is earth! Should i post a pic? Link to comment Share on other sites More sharing options...
R32North Posted May 24, 2005 Report Share Posted May 24, 2005 [ QUOTE ] On my Satnav unit, the Brown wire is earth! Should i post a pic? [/ QUOTE ] Rules seem to have changed then! Always good to check 1st tho!! Link to comment Share on other sites More sharing options...
Skidmark Posted May 24, 2005 Report Share Posted May 24, 2005 [ QUOTE ] as above nees to know which to tap into for the earth on my dension ice link. [/ QUOTE ] have a look at : www.vwNavi.com the plug & play wiring harness installation... wire colours/pins/etc Link to comment Share on other sites More sharing options...
Zenyck100 Posted May 24, 2005 Author Report Share Posted May 24, 2005 cheers Link to comment Share on other sites More sharing options...
mb Posted May 25, 2005 Report Share Posted May 25, 2005 Earth is usually brown but that plug & play wiring loom isn't for our cars - easiest way is to check for continuity ! If you pull the stereo there is a map on the side with all the pins & what they do - this should make like easier. There aren't a lot of wires, as it seems a fair bit of info is taken via the CAN bus & some trickery (gala, lighting, 12V switched etc.) HtH Martin Link to comment Share on other sites More sharing options...
Skidmark Posted May 25, 2005 Report Share Posted May 25, 2005 [ QUOTE ] Earth is usually brown but that plug & play wiring loom isn't for our cars - easiest way is to check for continuity ! [/ QUOTE ] I know....it was a quick way of getting info across... ....and it was bed time.. Link to comment Share on other sites More sharing options...
