Remote window drop/lift.
Ari
My previous two Audis had a function whereby if you unlocked the car and held your finger on the "unlock" the windows would drop. Equally, if you locked it and kept your finger on the windows would rise (and sunroof would close on the one with the sunroof). My A4 Cabriolet doesn't seem to do this and I wondered if it could be enabled via vag-com?
Also, when dropping the roof from the button inside or from using the igntion key (if you unlock the car then put the key in the door and turn it in the unlock direction twice and hold it then the roof folds, useful on hot days when the interior heats up as you can drop the roof before getting in the car. Also works in reverse, ie turn to lock twice and hold and the roof goes up) the windows lower half way to enable the roof to drop, then when the roof is folded they raise back up to fully up. I wondered if this preset could be altered so the windows dropped right down once the roof had folded? More useful on a hot day as then the car will be fully open (ie roof down, all windows down) on one touch.
Just curious.
