'04 Saloon/Avant Door the same?
Ben
Front doors will be exactly the same, surely? Front doorglass I can certainly confirm is identical for the saloon and avant.
Rear skins are - perhaps surprisingly - the same on the saloon and avant iirc. However, the framework to hold the glass is visibly quite different: The roof tappers on the saloon quite markedly from the B post, whereas this is much more gradual on the avant. The doorglasses are [obviously] different.
<font color="#666666">Also, the avant has a much thicker C pillar between the rear doorglass and the [larger] rear quarter, whereas the saloon had a much thinner strip separating the [small] rear quarter as the main C pillar is just behind holding in the rear screen.</font>
Ian
