Markallain Posted July 7, 2005 Report Share Posted July 7, 2005 How do I do this on my pc? Link to comment Share on other sites More sharing options...
a4tdi130 Posted July 7, 2005 Report Share Posted July 7, 2005 From what I've heard it's just a bog standard data disc so use any normal CD writing software such as Nero, PrimoPrassi, etc. Both of these have a "disk to disk" copy option and shouldn't need any settings changes for it to work. Link to comment Share on other sites More sharing options...
craigyb Posted July 7, 2005 Report Share Posted July 7, 2005 the 2004 disk copied ok using NEro, but I never managed to copy the 2005 disks. Link to comment Share on other sites More sharing options...
Markallain Posted July 7, 2005 Author Report Share Posted July 7, 2005 Where do I get hold of Nero? And was it a DVD 2005 disc which would not copy? Link to comment Share on other sites More sharing options...
craigyb Posted July 7, 2005 Report Share Posted July 7, 2005 Ok, a DVD not a CD, I copy the 2005 DVD no problems using Alcohol 120%, it's a DL disk though so you must use a DL writer. DVD+R DL 9GB Link to comment Share on other sites More sharing options...
Markallain Posted July 7, 2005 Author Report Share Posted July 7, 2005 Thanks Craigy I'll give this a go - not sure what you meant by a DL disc though + other details you mention. Mine is CD Rom based. Is alcohol still the one to use? Link to comment Share on other sites More sharing options...
craigyb Posted July 7, 2005 Report Share Posted July 7, 2005 Sorry, I'm confusing you..... 1. I could not copy a 2005 CD using any method 2. I could copy the 2004 CD's ok 3. The 2005 DVD for the RNS-E is a dual layer disk Craig Link to comment Share on other sites More sharing options...
a4tdi130 Posted July 8, 2005 Report Share Posted July 8, 2005 Mark - let's make this easy What disc do you have? Link to comment Share on other sites More sharing options...
Markallain Posted July 8, 2005 Author Report Share Posted July 8, 2005 Teleatlas 2004/5 DX disc - hope this is enough info? Link to comment Share on other sites More sharing options...
Smudge Posted July 14, 2005 Report Share Posted July 14, 2005 Mark / anyone else. Has anyone managed to copy the VW '05 Sat Nav CD rom yet? Link to comment Share on other sites More sharing options...
Markallain Posted July 14, 2005 Author Report Share Posted July 14, 2005 I've got some complicated instructions on how to do this which don't mean a thing to me! Will give it a go at the weekend. Are you good with these types of things smudge as I will probably need some help! Mark Link to comment Share on other sites More sharing options...
Markallain Posted July 15, 2005 Author Report Share Posted July 15, 2005 One failed copy already Link to comment Share on other sites More sharing options...
a4tdi130 Posted July 15, 2005 Report Share Posted July 15, 2005 I know my way around most CD copying packages - do you want to post the instructions on here so we know what you're trying to do? Link to comment Share on other sites More sharing options...
Markallain Posted July 15, 2005 Author Report Share Posted July 15, 2005 Cheers I've sent you a PM Mark Link to comment Share on other sites More sharing options...
Wobby Posted July 15, 2005 Report Share Posted July 15, 2005 IS THAT LEGAL?? you wanna sell me a "back up" copy. I already have the disk but i dont know how to copy it !! Link to comment Share on other sites More sharing options...
a4tdi130 Posted July 15, 2005 Report Share Posted July 15, 2005 Making a backup for yourself is legal. If you want to use the headunit to play music it means constantly removing the satnav disc, and if it gets ruined it's not cheap to get a new one from Audi. Better to make a copy, keep the original safe in the house, and if the copy gets knackered, just burn another one. Selling them or giving them away to other people would of course be illegal though. Link to comment Share on other sites More sharing options...
Markallain Posted July 16, 2005 Author Report Share Posted July 16, 2005 Still trying to make a backup!!!!!!!!! Do these instructions mean something to one of you? "Maps in version 3 are copy-protected with safedisk ver 2. mechanism. If you do not burn the copy in right way, you will get only CD IS INCOMPATIBLE on your Sat-Nav screen. To create working copy of version 3 map CD you will need a CD burner drive, capable of sucesfully bypassing/burning Safedisk 2 protection. Your success or failure depends 90% on the drive + 10% on media you use. Basically, you should use one of 2-sheeps drivers listed on this page: http://www.makeabackup.com/modules.php?name=Burner_Attributes I have been sucesfull with LG GSA-4040B DVD/CD burning drive. Open the attached CD image (about 170 MB) with CloneCD. Used attached CloneCD profile ("SafeDisc 2.9x.ccp"). It will set all writing parameters for you. Burn with RAW DAO mode Burn with SLOW speed. I did with 1 or 2x. 4x sometimes does not work. Maximum speed does not work for sure. Burn on quality media! - Memorex, Philips are fine. ( I lost half day, because of playing with cheap meida. Sat-Nav could not read them, giving me "Incompatible disk" message, after 30s of "activating Sat-Nav") Comments ---------- If you have a 2-sheeps drive (and you really should have one) then "Amplify weak sectors" option should be off. It is not necessary by 2 sheep drivers. It should be possible to create working copy with 1-sheep burner too (with Amplify weak sectors ON), but it did not worked for me. With old burn drivers you have no chance at all." Link to comment Share on other sites More sharing options...
Rustynuts Posted July 16, 2005 Report Share Posted July 16, 2005 You sound like you've been reading "Afterdawn" forums. If not, that could be where you'd get some help. For your information, "Alcohol 120" is safedisk 2 enabled, and should walk it. Safedisk version 3 it has a little difficulty with, something like you're detailing here, but I've backed up loads of Safedisk 2 stuff. "A-ray scanner" is a free tool for checking which copy protection is on cd's, if you can get it and "Alcohol" you should be away. Link to comment Share on other sites More sharing options...
Markallain Posted July 16, 2005 Author Report Share Posted July 16, 2005 Is alcohol 120 free to download? Link to comment Share on other sites More sharing options...
Rustynuts Posted July 16, 2005 Report Share Posted July 16, 2005 Free trial I seem to remember. Link to comment Share on other sites More sharing options...
Markallain Posted July 16, 2005 Author Report Share Posted July 16, 2005 Thanks Think I've found it Link to comment Share on other sites More sharing options...
Rustynuts Posted July 16, 2005 Report Share Posted July 16, 2005 Yep, it's on www.download.com. If you want A-Ray, I've got a copy I can E mail you, it's only 480Kb. Link to comment Share on other sites More sharing options...
Markallain Posted July 16, 2005 Author Report Share Posted July 16, 2005 Alcohol has already come up with a load of disc read errors which I guess means it won't work? Link to comment Share on other sites More sharing options...
Markallain Posted July 16, 2005 Author Report Share Posted July 16, 2005 Yes please send me A ray but what will it tell me? Link to comment Share on other sites More sharing options...
Rustynuts Posted July 16, 2005 Report Share Posted July 16, 2005 A ray will confirm the copy protection which is on the disk, and then you have to set Alcohol to ignore that particular copy protection. Here's a screen shot from alcohol. down at the bottom where it says "Customise" is a drop down menu. Select Safedisk 2 from there, and it applies the correct parameters. Link to comment Share on other sites More sharing options...
