glennjacobs Posted July 25, 2005 Report Share Posted July 25, 2005 Hi, I've just bought a 1998 Passat and have the standard radio/cassette. I want to upgrade this to the Gamma radio and the in-dash 6 CD player, but it also has climate control. Can I fit all of these in the Passat? Is there some sort of mounting/blanking plate for the dash to help do this? Please help Link to comment Share on other sites More sharing options...
shao_khan Posted July 25, 2005 Report Share Posted July 25, 2005 I can never remember what years dashs changed. But depends on the dash you have then some will need revised Aircon controls, others will have a Radio slot, and a DIN sized 'cubbyhole'. If you have the latter then you may need a different chassis, but you should be able to remove the radio and cubby hole and replace with the parts you mention. IF it were me, I would consider a replacement head unit with MP3 capability (obviously if you have fascility to record MP3 onto CD) - this saves messing around 2 much, it gives you around 10 - 15 albums per CD so saves the need of a cd changer, and in general you will get better quality (peraps even DAB). Link to comment Share on other sites More sharing options...
glennjacobs Posted July 25, 2005 Author Report Share Posted July 25, 2005 Yeah, hadn't thought about the MP3 route. Can you recommend a head unit? I don't want to pay any more than about 100 quid really and really don't want one of those naff ones that have loads of lights flying around everywhere Link to comment Share on other sites More sharing options...
shao_khan Posted July 25, 2005 Report Share Posted July 25, 2005 Well in the past I have only eevr had Sony, Alpine and Blaupunkt units and have never had a fault with any. TO be honest I would have a look around (even the local Halfords) and see what you like the look of - a lot have flash displays, several have the blue/red from VW so they pretty much match the existing OEM display. I think If I were going for a new HU at the moment I would be looking at something like the Blaupunkt Woodstock as it is MP3 and DAB - it is more than the budget you have specified, but it appears to review well and looks pretty good (IMO). I would look for easy use (some appear to need a 14 button combo to turn them on), fascilities (MP3, cdr/rw compatible, etc) and general appearance. Link to comment Share on other sites More sharing options...
