Major Problems with PD130 engine
badgera
Anybody had major problems with a PD130 engine?
A friend of mine has a PD130 GTTDi as a company car. He is about to change it (3 years old) and it has 95K on it.
On his way to work at the end of last week it started to sound a little more like a tractor than normal, so he slowed down, opened the window (to check that it was his car making the noise) and was about to divert to the dealer, when it stopped.
No oil warning light or anything other than the noise and it wouldn't do anything. UHOH7.GIF
He's had the message back today that it needs a new engine EEK2.GIF (£2990 plus VAT), there's talk of bent con-rods, but the timing belt was fine.
The cars been service reguarly, kept topped with oil and driven briskly.
Anybody else experienced this? I'd expect this sort of thing shouldn't happen to a maintained modern engine.
Andrew
Did he drive though water or It could have been the turbo blow and sucked oil in to the engine(combustion chamber) and with the engine unable to compress oil it has just bent the con rods etc etc,
If the turbo had gone it would have reved the engine up past it safe limit. Beacuse the engine would run on the engine oil and the rev limiter is built into the fuel system with that bypasses they just rev till the valves hit the pistions.
Andrew
Ok, you say it stoped after he slowed down, Did he try cranking it over after it had stopped? If he did, did it crank over or was it solid?
When was the timing belt replaced? and by who?
Possibly the lifters failed, I've heard of this a couple of times, but I don't see how this would bend con rods unless the valves dropped into the bores! It's got to be something to do with valve / piston interference somehow. Maybe the timing belt job was goofed and the pistons hit a valve or two, then the shop realised, and set it all up correctly. Later down the road, the valve could fail and cause the damage we have here. confused.gif
I think after it stopped it wouldn't crank over (i.e. it was siezed).
the timing belt was changed by the VW main dealer at 70Kish. It's been maintained as per the book (or at least been taken in to be maintained as per the book).
I just wondered if many "blown" engines had been reported.
  • 3 months later...
