yiman Posted November 10, 2005 Report Share Posted November 10, 2005 My A3 Tdi has 800 miles on the clock and since I've had it I've been irritated by a weird whistling noise which sounds like it's coming from the back end, passenger side. It doesn't sound anything untoward at all, it's just like a low whistle - like an owl's hoot, which builds up and dies down at a certain point in the throttle range. Has anyone else experienced anything like this? Can't face the hassle at the moment of returning to dealer for something relatively minor. Any advice or infio appreciated. Link to comment Share on other sites More sharing options...
Wallachie Posted November 10, 2005 Report Share Posted November 10, 2005 Maybe it's your turbo!! Just kidding! Sounds like wind noise to me, check your door seals etc. Other than that I wouldn't really know. Link to comment Share on other sites More sharing options...
yiman Posted November 10, 2005 Author Report Share Posted November 10, 2005 Think it's deffo not wind noise as the generation of the noise is strictly throttle controlled and happens at all speeds. Link to comment Share on other sites More sharing options...
dgl Posted November 10, 2005 Report Share Posted November 10, 2005 Well I think Mills first answer could be correct. Do you think the noise coincides with the turbo kicking in? 3000 revs I think?? Link to comment Share on other sites More sharing options...
Rustynuts Posted November 10, 2005 Report Share Posted November 10, 2005 A3 TDI turbo will be coming onto song at about 1500 - 1700 rpm. Link to comment Share on other sites More sharing options...
yiman Posted November 10, 2005 Author Report Share Posted November 10, 2005 Will check - could be highly likely. Link to comment Share on other sites More sharing options...
runflat Posted November 11, 2005 Report Share Posted November 11, 2005 sounds exactly like the turbo whistle. Tends to be hard to pin down exactly where noises are coming from in cars, but I would bet this is what it is. Link to comment Share on other sites More sharing options...
yiman Posted November 14, 2005 Author Report Share Posted November 14, 2005 The sound happens at between 1500 and 2100 rpm, depending on gear. Is turbo-whistle just what turbos do or is it a sign of something awry? Link to comment Share on other sites More sharing options...
Rustynuts Posted November 14, 2005 Report Share Posted November 14, 2005 Oh, what a lovely sound, as long as it's coming from the turbine and not the bearings. If you drive alongside a wall with the window down, you can make it whistle by playing with the throttle (even though diesels don't have a throttle). It's just something that turbos do, as it's the vanes of the turbine spinning through the air. Link to comment Share on other sites More sharing options...
DukeDesmo Posted November 14, 2005 Report Share Posted November 14, 2005 Could it be one of these? http://www.sillyjokes.co.uk/p-jokes/surprise/exhaust-whistle.html Link to comment Share on other sites More sharing options...
Rustynuts Posted November 14, 2005 Report Share Posted November 14, 2005 [ QUOTE ] For dual exhausts, buy two whistles. [/ QUOTE ] Quality sales technique. Link to comment Share on other sites More sharing options...
Guest slittley Posted November 15, 2005 Report Share Posted November 15, 2005 I have exactly the same car (2.0TDI) and have had mine from new in September. I also get a whistling noise which is difficult to determine where it comes from (it appears to be coming from inside the cabin although this is unlikely). It's a low-pitched sound and sounds like someone is blowing over the top of a bottle. The car has been back to the dealership who thought that it was a resonance in the air intake path (I agree with this diagnosis as it appears to be related to engine speed/throttle position/engine load). The "fix" apparently recommended by Audi was to replace the turbo impeller. This was supposedly carried out by the dealership and they told me that the noise had been eliminated. However, on driving the car away from the dealership after having the noise "fixed", it quickly became apparent that it was still there. I haven't taken the car back again, partly because I plan on changing the car for a petrol turbo version early next year but had I been planning on keeping the it for some time, I would have insisted on the fault being rectified. While the noise isn't very loud, it is present often enough to become irritating and you should expect nothing less than close to perfection on a brand new car. Please keep us posted on your progress with the problem. Good luck! Steve Link to comment Share on other sites More sharing options...
Guest slittley Posted November 15, 2005 Report Share Posted November 15, 2005 Correction to the above: Audi identified the noise problem as originating from the turbo impeller. The fix was to "replace the turbocharger" which the dealer claimed to have carried out (but given the fact that it made zero difference, I'm not 100% convinced they did this). Steve Link to comment Share on other sites More sharing options...
yiman Posted November 15, 2005 Author Report Share Posted November 15, 2005 Cheers Steve this sounds like exactly the same thing. I've got the car for four years so looks like a visit to the dealer to get this irritation fixed. Link to comment Share on other sites More sharing options...
