Clembo Posted November 16, 2005 Report Share Posted November 16, 2005 Folks, the wife has recently bought a new 55 plate 3 door Polo 1.4 Sport. As its now getting colder we have noticed that there appears to be alot of condensation inside the car on the windscreen? This is first thing in the morning or at night when she is leaving work. Is this normal? As my current and old car along with her old Pug 206 never had such problems? Thinking about going to the local Stealer but have a feeling I'll get fobbed off. Cheers, Paul Link to comment Share on other sites More sharing options...
Ritey Posted November 16, 2005 Report Share Posted November 16, 2005 Do you have air con? Link to comment Share on other sites More sharing options...
Clembo Posted November 16, 2005 Author Report Share Posted November 16, 2005 Yup Link to comment Share on other sites More sharing options...
A3Floyd Posted November 16, 2005 Report Share Posted November 16, 2005 Our Yaris used to do the same thing. I found that closing the interior vents at night did the job. It seems that the moisture from the air outside was getting into the car via the heater vents. Not sure why it only affected the Yaris and not the Audis but worth a try. Link to comment Share on other sites More sharing options...
Ritey Posted November 16, 2005 Report Share Posted November 16, 2005 My old polo used to do it when I first got it, I rubbed the interior glass with newspaper and it seemed to cure it Link to comment Share on other sites More sharing options...
R32North Posted November 16, 2005 Report Share Posted November 16, 2005 Don't wipe with with a cloth, sponge or similar thing as this can leave grease and micro deposits on the glass, and it will continue to trap moisture and condensate over night! I'd simply use the heaters to dry the car out and keep the vents closed. Also, avoid parking into the wind and this assists moisture laden air getting into the car. Link to comment Share on other sites More sharing options...
Skidmark Posted November 16, 2005 Report Share Posted November 16, 2005 It is worth checking for water in the car, there may be a leak. check the carpets [back and front] also the boot [under the mat]....has it got a s/roof..poss blocked or dislodged drains ? good luck Link to comment Share on other sites More sharing options...
Clembo Posted November 16, 2005 Author Report Share Posted November 16, 2005 Thanks guys for the advise, I will close the vents tonight. Oh and it better not have water in the footwell .. she's only done 700 miles !! Link to comment Share on other sites More sharing options...
Skidmark Posted November 16, 2005 Report Share Posted November 16, 2005 [ QUOTE ] Oh and it better not have water in the footwell .. she's only done 700 miles !! [/ QUOTE ] I hope not too ! ..mine was ex demo from main dealer.....had battery acid spilt in the boot & not cleaned out !! good luck Link to comment Share on other sites More sharing options...
Riz Posted November 17, 2005 Report Share Posted November 17, 2005 If anybody else has problems with condensation heres a little tip..... You can find these little pouches/bags in tv, computer packaging etc.... they call them crystal gel`s etc. Put a bag or two under your car seats and that should keep the condensation away... also make sure before you swtich your a/c unit off you put it on recirculation, this will close the outside inlet pipes. Riz Link to comment Share on other sites More sharing options...
DaddyDub Posted November 28, 2005 Report Share Posted November 28, 2005 Just another thought. If you get into your car with wet shoes a couple of times a day and it's cold, it's enough water inside the vehicle to make a lot of condensation on the windows. Link to comment Share on other sites More sharing options...
