Common faults on a VW Golf/Bora 1998 > 2004
mulkbear
<font color="blue">Common faults on a Golf/Bora 1998 > 2005 </font>
<font color="blue">General faults </font>
1) F. Window drops into door and will not come up
C. Window regulator clips have snapped
C. Window regulator is repaired with a window regulator repair kit
2) F. No brake lamps when brake pedal is pressed
C. Both brake bulbs have blown or brake pedal switch has failed.
C. Replace bulbs or brake pedal switch.
3) F. Wipers slow or stopped mid wipe
C. Wiper linkage seized
C. Wiper linkage is replaced
4) F. Rear washer in/op
C. Connection joint for the water supply to the rear washer jet has come off
C. Reconnect pipe with a small jubilee clip.
5) F. Warning boot open lamp on when boot is closed
C. Water ingress into boot latch caused by fault 4
C. Dry on boot latch switch or replace boot catch.
6) F. Temperature gauge in/op and poor running when cold
C. Faulty coolant temperature sensor
C. Replace coolant temperature sensor
<font color="blue">1.6 8V Engine AKL faults </font>
1) F. Engine revs high or cutting out at junctions
C. Oil deposits and carbon build up in the throttle body housing
C. Throttle body housing is cleaned and adapted.
2) F. Light misfire at idle and light throttle
C. H.T. leads or sparking plugs faulty
C. Replace faulty item
3) F. Rough idle
C. Burnt out inlet or exhaust valve
C. Cylinder head is removed and burnt out valve is replaced
4) F. Loss of drive and clutch
C. Machining defect in gearbox housing allows gear box parts to come though bell housing causing gear box oil to contaminate the clutch.
C. Replacement of gearbox, clutch assembly and in some case’s flywheel
(Common post 60k miles)
<font color="blue">1.9 TDI PD Engine ATD, AJM, ASZ and ARL Faults</font>
1) F. Lack of power in General
C. Air mass meter has failed
C. Replace air mass meter
2) F. Lack of turbo power plus whooshing when turbo kicks in
C. Turbo pipe has split or connection has failed
C. Reconnect the turbo pipe or replace defective turbo pipe.
3) F. Loss of power after a short drive but switch ignition off and on and regains power.
C. Fault with turbo system causing safety system to turn turbo off.
C. Replacement of turbo or maybe several other faults
<font color="blue">1.8 20V Turbo Engine AUM, AUQ Faults</font>
1) F. Light rattling noise from engine at start up
C. Lack of oil pressure to cam chain tensioner
C. Replacement of cam chain tensioner or clean out block oil feed pick up.
2) F. Contain misfire
C. Coil tower failure
C. Replacement of faulty coil tower
<font color="blue">1.9 SDI Engine AQM faults </font>
1) F. Lack of power
C. The engine is shite
C. Sell it and buy a real golf
Sticky ?
  • 2 weeks later...
You can add: Wires that go to the injectors may go brittle under the engine cover to the list, it causes misfiring on the pd engines. VW has told me it is a 'common' complaint. It cost me about 400 quid to replace the No.2 injector, not very happy at all. My car has only done 45000 miles.
Yes it did Wobby, something like 15667 misfire on cylinder 2. Can't remember exactly. And i also got a friendly auto electrician to just replace the wiring loom to the injectors. So i have to amend my previous post to say it could have cost me 450 quid plus vat smile.gif. The actual cost was 90 quid. The wiring itself sits inside the rocker cover and sits in a bath of oil! Strange. So don't be fobbed off with VW telling you you have to change the injector, it may be wise to change the wires first. I read somewhere else in this forum of the same thing, although i'm not saying his injector wasn't dead. But just maybe it wasn't :/
  • 2 weeks later...
Had the window thing go on. My take is that the rubbers at the top of the window get a little 'dry' and grab the glass. At the same time you depress the swith and the regulator drops towards the bottom of the door under control, when the window finally follows its uncontrolled and falls into the door recess smashing off the lifters on the regulator. I've applied a little wd40 to the rubbers and all seems a little more refined now.....we'll see if it works, but at £157 for the first replacement it must be worth a shot.
Here's another! The anti roll bar on the Bora seems to corrode quickly and needs replacement at around 100, 00 miles. At the dealers they tell me that this is becuase the ruber bushes holding it, tend to wear the powder coating away allowing corrosion. Try wd40 again to lubricate the junction between the two.
  • 1 month later...
Jeezus!
Here's another one. I have had mayo in the oil filler throut since I bought the car, it ruined the previous filler cap, and I replaced that hoping for an improvement. Not so. I also found the breather pipe going from the filler neck/ top of rocker cover leading to the inlet of the throttle body was chock a block full of mayo too. No sign of head gasket gone, no contamination elsewhere. Worrying though if you're not expecting to see it! WTF VW?
  • 1 year later...
Hi there. I'm a new user, looking for some help. I had the gearbox break on my golf, as the common faults listed and have now had it fixed. The car now makes a strange kind of dynamo noise now, when it is driven over 40 mph. It's a Golf 1.6 2000. No one seems to know what the noise is or how to fix it - can anyone help? The noise get's more high pitched the faster you go. Everything is fine with the new gerabox, it's all been checked over several times.
  • 2 months later...
My bora decided to have the lack of power fault til i reset the ignition fault for its 60000 mile birthday no lights showing a fault appeared on the dashboard tho. I just hope its the air sensor and not the turbo wont no till i check it on vag not only that ive shattered the engine splash guard on the same weekend gutted
The other fault not mentioned in your list is that boras seem to attract collisions with other cars 4 in one year none of them my fault, I should give up working and become a professional claimer
