Gemmzl Posted January 31, 2006 Report Share Posted January 31, 2006 Hi, My car has been doing little misfires recently and now a warning light has come on. It looks like a battery with a lightening bolt and it's orange. Got a feeling it's engine management??? Does anyone know what that means or is this a common fault? thanks Gem Link to comment Share on other sites More sharing options...
Ritey Posted January 31, 2006 Report Share Posted January 31, 2006 Has it been serviced at required intervals? Sounds like it could be an engine management problem but best to get it checked out Link to comment Share on other sites More sharing options...
Gemmzl Posted January 31, 2006 Author Report Share Posted January 31, 2006 Yes it was done at the end of Oct 05. Full VW SH EDIT: got it booked in for Saturday, will inform you of the results. (incase someone else has this problem) Link to comment Share on other sites More sharing options...
RobGTi Posted January 31, 2006 Report Share Posted January 31, 2006 My bet is that its your HT leads. Needed mine done a couple of weeks ago because it was misfiring (especially under load) Rob Link to comment Share on other sites More sharing options...
Si_GTi Posted January 31, 2006 Report Share Posted January 31, 2006 HT lead related problems seem to pop up all over the place at the moment with Polo owners! From what I've read though, in general if you are having problems with misfires and irregular running then replacing the HT leads *usually* cures things... Let us know how you get on with your friendly local dealership Gem! Link to comment Share on other sites More sharing options...
jimmyp Posted February 1, 2006 Report Share Posted February 1, 2006 The engine management light is the EPC light, and when i had a misfire it was the emmisions light that flashed up, but only for a short while, but if it stayed on it means the cat is on its way out. Not sure if this is any help but there you go anyway. Link to comment Share on other sites More sharing options...
Gemmzl Posted February 1, 2006 Author Report Share Posted February 1, 2006 It's not the EPC light. Would it misifre if the cat is on its way out? How much are HT leads roughly? Link to comment Share on other sites More sharing options...
Gemmzl Posted February 1, 2006 Author Report Share Posted February 1, 2006 Ok its the Exhaust Emission Warning Lamp. Weird thing is, it doesnt happen all the time and sometimes the car is fine. It was MOT'd in Dec, now if the Cat was on its wat out VW should have picked up on this, right? Do you think it could just be a lambda sensor? I'm hoping it is!!! Link to comment Share on other sites More sharing options...
Weedle Posted February 2, 2006 Report Share Posted February 2, 2006 I had the smae problem on my polo the EPC exhaust emissions light comes on when it feels like it - mine was the MAF sensor best thing to try and do is get a small local garage to clean the pressure mainfold sensor - i get mine done once a year and i have not had the problem come back --- YOU DO NOT NEED TO REPLACE IT - they might try to get you to replace dont it just get it cleaned it will be fine Link to comment Share on other sites More sharing options...
jimmyp Posted February 3, 2006 Report Share Posted February 3, 2006 [ QUOTE ] when i had a misfire it was the emmisions light that flashed up [/ QUOTE ] Mine only did it for a while as well until i got it checked and found out it was a coil pack misfiring, do the polo's have coils packs i'm not sure but try and get it plugged in to vagcom and this will tell you what is going on in your engine. HTH Link to comment Share on other sites More sharing options...
jimmyp Posted February 3, 2006 Report Share Posted February 3, 2006 [ QUOTE ] Ok its the Exhaust Emission Warning Lamp. [/ QUOTE ] See above. Link to comment Share on other sites More sharing options...
