[Audi A3/S3] K&N Filter bad results against Audi OEM Filter!
harddrive
The other week I was reading a post about how the K&N panel filter can stuff up the Mass airflow sensor. I apparently does this by coating it will a haze of oil from the panel itself.
I was also reading that in some cases performance of airflow was worse over that of the OEM filter fitted by the dealer.
I had fitted a K&N panel filter on my A3 3.2L about 4 months ago and was starting to notice a drop in acceleration in high gears as well as a heavy decrease in the coolant level.
Luckily I had just got access to a VAG-COM cable so I decided to run a number of tests between the OEM panel and the K&N.
First I ran a test with the K&N and the engine cold. Then the same test data again after a run of 20 minutes. I then swapped over the panel back to the OEM unit and ran the same tests with that fitted. Surprisingly I found that the K&N was passing less air to the engine than OEM filer according to the data readout. I also found that when I drove the car with the OEM filter the performance was noticeably better
On another plus note my fuel economy has also increased from 25.9 MPG to 29.7 MPG
So the moral of the story is stick to OEM as you save money and MAF sensors!!!
I have taken some of the data and created the attached graph so you can see the differences between the two: grin.gifjump.gif
I just replaced the paper filter on my S3 with a Pipercross replacement panel filter and the difference in flow rates is substantial.
The engine feels more willing to pull, is quicker throughout the rev range and there is a noticeable increase in torque.
Whether the existing panel needed changing anyway or the Piper is just better, I don't know? But there is a noticeable difference, you can hear the air flowing more freely!
The Pipercross foam used is designed especially for the VAG series and doesn't feature any additives to contaminate the MAF sensor.
I've got a few K&N's lying around, replacement filters and 57i's and like Paul said (Happy Birthday by the way!)....I wouldn't put them anywhere near a modern engine, they're designed for old school draggers with no electronics, besides the point......that red oil is a bugger to wash off! ECLIPSe.gif
Haven't changed mine yet smashfreakB.gif. Is it easy to do? Can someone show me the way please?
Easy.
Unplug MAF.
Undo Jubilee on the Turbo intake pipe on the MAF
Remove two philips screws on the bulk head side of airbox lid
and its free to come off.
Although pics would be a great help so that i dont feck it up! smirk.gif (Wouldn't ask if i didn't have a habbit of doing that - trust me crazy.gif)
Hmmm... think I should revert back to the OEM then! Was unsure whether the K&N had made any difference, but stuck with it anyway.
How much is a standard part then? £10?
With the air filter potentially buggering things up, it's just another to the list of things wrong with my stinker of an A3...
- Constant faulty brake lights
- Numerous rattles & squeaks
- Slack fan belt
- Small hole in exhaust joint
- Drivers seat won't latch down
- Poor MPG at the moment (could this be to do with the air filter?)
Not what you need when you're moving into your first flat! Think she needs a week in a health spa to detox!
