malarcy Posted February 16, 2006 Report Share Posted February 16, 2006 Got an aplpine head and alpine ipod adapter fitted at my local ICE place. They seem to have done a reasonable job - except they had the wrong harness adapter for my car (apparently a4 cabriolets have amped speakers) - that's coming in on friday Outstanding issue is - power off with ignition, have read various posts around the net varied from 1) can't do it, these cars use k-bus signalling for ignition 2) can do, these cares use k-bus but there is an adapter from soundlinx.co.uk (their website is broken so I can;t check) 3) AUDI/VW often transpose 12v permamnent with 12v accessory (switched 12v) on the harness - just switch them around. Can anyone give me a definative version - if I have to hang something 3rd party on the k-bus line then I might just rip it all out and put the audi head unit back - this shouldn't be that hard. Any help appreciated. Paul Link to comment Share on other sites More sharing options...
timps Posted February 16, 2006 Report Share Posted February 16, 2006 All those post are true but it depends on the year of car and the original radio. Which ever way there is a switched ignition feed in the steering column behind the key switch. My original radio used k-bus to switch on and off so when I changed to a Kenwood I did a little testing. When I checked the wires in the steering column behind the key switch with a multi meter on my A4 B6 there was Permanent live Switched live thick cable (but only in the accessory position) Switched live thin cable (until key removed) (this one I think is to tell k-bus your key is in the ignition but not a k-bus wire) I used the last one with a very low rated fuse for a switch live Hope this helps Link to comment Share on other sites More sharing options...
malarcy Posted February 16, 2006 Author Report Share Posted February 16, 2006 Thanks for that, the only thing stopping me from doing that is not giving the stealers any more excuses for not fixing things - I am so expecting them to whine and moan whenever they get near the car that I am actually planning on removing the head unit when they have the car - if I have an adapter I can pull it - but a splice wire will be a bit more permanent. One local ICE installer is looking into the soundlinx stuff for me - I'll see where I go from there. Paul Link to comment Share on other sites More sharing options...
timps Posted February 16, 2006 Report Share Posted February 16, 2006 Some people have actually trapped a wire in the fuse box with a fuse. There is definitely a switched live in the fuse box of a B6 & it would be very easy to cover your tracks if need be but this is only live in the accessory position and the idea of a trapped wire does put some people off. Link to comment Share on other sites More sharing options...
malarcy Posted February 16, 2006 Author Report Share Posted February 16, 2006 The soundlinx unit is ....... 190 pounds. hell fire and damnation to it - sounds like I am living with turning the bugger off when I switch the car off. Still let's see what my "expert" says tomorrow when the speakers get connected properly. Thanks all Paul Link to comment Share on other sites More sharing options...
malarcy Posted February 17, 2006 Author Report Share Posted February 17, 2006 Just to wrap this up - went back today, the correct cable was fitted, switched live and lights on (dimming for the unit) connected up, aerial amplifier fitted (another surprise) and..... it sounds crap - all treble up front, distorts like a b*st*rd, rears all bass and quiet have to have fader set all the way back to stop it sounding like someone else's walkman - and - the stupid bloody glidebar thing goes off over bumps - I think the unit is actually faulty - one end is OK the other needs a breathe of wind on it before it selects. It's all coming out next weekend - the original audi head going back in and I am giving up on the whole thing If my experience is anything to go by - if you have an a4 cabriolet and want to change the head unit DONT. Thanks for listening. Paul Link to comment Share on other sites More sharing options...
