[Audi A3/S3] inconsistent boost and revs 'hanging'
s3ollie
after fitting a new air flow sensor toady at a cost of around £90 it has fixed any issues i had and now feels like a new car.
when i asking at the audi parts desk if the air flow sensor is a problem with the s3 i was told "its a stock item!!" & the problem is "across the range"
So all i can say is if you are experiencing irratic behaviour from your vag engine check / replace the air flow sensor
On the early cars you can disconnect the wires to the sensor and run the car to see if goes better without the MAF doing the calculations - hence you may find out if the MAF is to blame.
On the later cars this may cause the management light to come up on the dash.
Cheers
Ben
Thanks for this info guys, I'm going to change my DV soon to try and rectify my "revs hanging" problem. On a few posts I've read about the Forge Eliminator DV, anyone have any comments on this particular DV? I dont want one that makes a boy racer sound, but wouldnt mind a little noise...
Remember noise = boost, or lack of it as it vents it out of the system.
Always makes me laugh when I hear some Jap car dumping 1 bar of boost out then having to wait for the turbo to produce it again!
Keep to a valve that re-circs, one of Forges will be great, I've ran them on my A3, S3 and RS4 and had no issues what so ever - give Russell a bell grin.gif
Cheers
Ben
